joints for laminated members
micheal
i have a project in mind that will require the uses of several laminated parts. are there any cautions as to types of wood joints to be used with laminated parts?
Re: joints for laminated members
It would sure help if you could be more specific.
Keith Newton
Anyone wanting to help might be able to write a few paragraphs, rather than the whole book.
micheal
the project invisioned is the recreation in laminated wood the frame work of old style human powered tools. because of the organic shape of these old machines it seems to me that the parts would best be made with laminated lumber. the only common laminated material in my shop is plywood and i dont use the all same jointing methods with it that i use with dimensional lumber or mdf. j osgood is credited with developing joints for his work that are unique to him and apparently his wide uses of laminated parts. he is apparently not available to quiz on the matter of jointing laminated parts so ive come here. one source suggested that the parts be jointed with floating tenions. before i invest the time and material in the projectid like to know that it wont be screwed up by bad or inappropate joints. im not after a book just a quick list of do's and dont's and possiblely a list of joints that work with laminated parts. thank you
PaulSV
If you are laminating solid wood (not plywood) with the grain all running in the same direction (not cross-grain, as in plywood) you can use the same joints that you use with solid wood. (For example, if you laminate six 1/4" x 4" by, say, 4' pieces of wood together, around a curved frame to form a 1 and 1/2 x 4" by 4' curved member.) This is often done for things like curved drawer fronts or table aprons.
If you are talking about a butcher block lamination (say sixteen 3/4 by 3/4 by 1 foot curved pieces to make a 1 and 1/2" by 1 and 1/2" curved member 4 feet long), then make sure to stagger the end-grain joints between layers of the lamination, and keep the end grain joints in the lamination away from where you are cutting joints. Again, use the same joints you would use for solid wood. The type of lamination in the first paragraph would be stronger than this, but both would be fairly strong.
One joint that is often used for things like attaching legs to a laminated table apron is the "bridle joint." (If you are not familiar with them, google for images of bridle joints.) That or normal mortise and tenon joints would work well for these types of laminations, and give lots of glue surface area.
Hope this helps for what you are trying to do.
Lamination
Laminated parts is a huge category. Without knowing the actual shape and size of the tools you're trying to re-create, it's hard to give you a specific strategy. Jere Osgood is well known for his bent laminated structures. If that's what you're thinking, I can't think of a reason to use tenons or other interpenetrating joints, as long-grain should do you fine. Epoxy may be your friend, too.
If you could show us what you're up to, my hunch is that we could give you a more specific answer.
Ellis Walentine, Host
micheal
paulsv: thanks for responding and yes it does help.
Re: Lamination
Jesse Cloud
A well made lamination should have the qualities of regular hardwood. One does have to avoid cuts that will expose the layers of lamination, but only for aesthetic reasons. Mortise and tenon work fine. Floating tenons are easier in the sense that laminated pieces are usually curved, and it is much easier to deal with floating tenons at 90 degrees from the joint face than integral tenons at somewhat arbitrary angles. There are jigs that facilitate cuting tenons at angles on curved pieces (see recent articles by Michael Fortune in Fine Woodworking). Personally, I prefer loose tenons and have never had one fail.
The gateway to successful laminated joinery is to make your lamination dead square from the top edge to the face edge - not as easy as it might seem.
