We value your privacy.
I bough a used router table. It came with a Bosch router and I would like to use a new Freud router which has a slightly larger diameter body which doesn't fit in the locking assembly that holds the router. Is it possible to get after market parts to modify the thing that holds the router to enable a different router to be mounted or does one have to by a whole new assembly to accommodate a different router?
It depends on which JessEm router lift you have. They make them in two sizes. The smaller size fits PC 690 and PC 890 series cylindrical bodies that are 3-1/2" in diameter (and other off brands of the same diameter). If you have the smaller lift, you are out of luck. The larger lifts fit the larger PC 7518 which is 4-1/4" in diameter. JessEm makes insert rings for these lifts, that adapt them to smaller diameter routers. One of these adaptors is for 3-1/2" routers, and another is for another diameter whose dimensions and diameter I don't care about. JessEm's most recent lifts, e.g., the Mast-R-Lift II, are equipped with adjustable cams that will hold several different diameter router barrels, so no adaptors need be bought. None of the JessEm lists are designed to hold routers that do not have cylindrical bodies.
IMHO, If you have a JessEm lift made in Canada, go get a PC router body that fits it. You'll be happy.
