Finishing OSB
Finishing OSB
Finishing OSB
Gary Evans
Hi all,
I have a ceiling in my shop that was done in OSB. I want to paint it, but I'd like to fill some of the voids so it doesn't look quite so much like OSB. Anybody done this? I found a masonry paint that is designed to fill the voids on concrete block, but I'm afraid it might not be flexible enough to last on a wood ceiling.
Any tips would be appreciated.
Gary
Re: Finishing OSB
Bob
Re: Finishing OSB
Bob
Try mixing the paint/primer with drywall compound and a heavy nap roller, after its dry give it a second coat of semi-gloss.
Re: Finishing OSB
Skim coat with joint compound?
Not a fun project, but I'd consider void-filling separately from painting. You might be able to get a good surface with joint compound.
Re: Finishing OSB
Re: Finishing OSB
Jerry Gibbs
How about covering the ceiling with pre-painted luan underlayment? You would have to pre-paint the luan.
Re: Finishing OSB
Try the paint
John in NM
Should be flexible enough if it's latex. Worst case it looks like painted OSB, which probably it will. I hate to say it, but if you don't want the ceiling to look like OSB, best solution is to use something else for the ceiling, like luan or drywall.
