Shaker Clock Works
Shaker Clock Works
Shaker Clock Works
jpleech in 'rural' festus, MO
Gearing up to make Christian Becksvoort's shaker clock that can be found here:
http://www.finewoodworking.com/pages/w00125.asp
Am running into trouble, however, determining which mechanical movement he used. I've downloaded the "free plan" from Taunton's website and it's nothing more than the article that's linked to above. Does anyone have source information on the movement. I know that he lists Merritts, but there is no mention of which movement and nothing on their site (that I could find) matches it.
Thanks,
JP
Re: Shaker Clock Works
Moses Yoder
Moses Yoder
Right at the top of the article it tells you to choose your movement and build the clock around it. If you are not capable of doing that, I would choose a different plan. The main choice is whether to get a spring wound or quartz battery operated movement; the difference in price is several hundred dollars.
del schisler
i been around clocks for yrs. that movement that it show's you will not find that one. It is a weight driven the old style. And pendlum which has to be set on beet to keep it running. The best for you is get a battery movement. I would get a battery with high tork for long hand's . A standerd short hand won't work with the longer hand's. You can get a movement from merrit's antique wich i have delt with for 50 or so yrs. It would be a time only which mean's that it has only one winding hole. Now you would also have to know the length of the pendlum with a wind up movement so that it would keep time with the adjustmen nut on the end of the pendlum rod. With a battery movement the length doesn't have any thing to do with the time ect. Just the length make's it look good. I have made hundred's of clock's over the 50 yrs. I used to mfd 9 different key wind clock and sell them in the antique trader yrs. ago. I hope this help's you understand clock movements. Also their are clock's than have 2 holes one for the chime and one for the run side. Now their are movements that 3 hole's those are westminster and 2 or more song's like whitting and whinchester and strike the 1/4 hour. Like 4 strik's and 8 strikes 12 strike's and 16 strike's and than strikes the hour. good luck
David Barnett
(Message Deleted by Poster)
Jim Dillon
JP,
I built that Shaker-style hanging clock as a special gift and it is a beauty. The movement that Becksvoort used was hand-built by David Lindow (Hartwig's Clock Company) in Lake Ariel, PA. My hand-painted dial was painted by John Martron, I think, at least that is who contacted me regarding a question. You really don't want to know the price, but if you are interested in building a heirloom piece, he may still be in business. Mr Lindow also taught clock movement design to woodworkers in Colonial Williamsburg - or at least did ten years ago, when I built the clock.
I agree with some of the other posters that less finicky (and much less expensive) options are available, and that it is important to know the approximate size of the movement prior to building.
I really, really wish I had it in my own home to enjoy. I would love to tackle a floor-standing Shaker-style clock, but time is short. Sigh!
Please feel free to e-mail me if you have any additional questions. Good luck!
Jim
S. LaRose, Inc has been out busisness for a while
Re: Shaker Clock Works *LINK*
Jim Dillon
A little snooping around turned up this web site for Mr. Lindow. Looks like he is still in business and has changed the name of his shop to David Lindow Clockworks.
As a side note, that article by Becksvoort caused some problems for Lindow at the time. Although my memory is a little fuzzy, I seem to recall when I spoke to Lindow, FWW was not supposed to publish his shop telephone number. Well they did, and consequently the phone was ringing off the hook preventing him from getting any work done. Things have calmed down by now I would imagine and I even see his web site caters to woodworkers. Hope this helps.
Jim
Here, as well, is a link from FWW to Lindow's Clockworks.
http://www.finewoodworking.com/Community/LettersDetail.aspx?id=31618
E-mail Christian directly
Carmen
I built a number of the Issac Newton Youngs clock. Before I did, I e-mailed Christian Beksvoort through Fine Woodworking. He responded to me directly with the answers to my questions and a few suggestions as well. You might get the answers you're looking for, too.
