Another Kilz vs. dog pee in stinky house question?
I have been posting about the house I bought that has terrible dog pee. We poured Clorox full strength on it, it foamed, but did not help. We tried Nature's Miracle Urine destroyer and it had no effect. So, today we cut out some of the worst areas and replaced the plywood.
We threw the old stuff out in the yard in the hot sun. Later I noticed the dark spots had sort of a wet look to them.
Several people have suggested Original Kilz. The oil based stuff, not the latex. I have bought five gallons of it, but I am reluctant to use it on such a slimy surface. I have been considering renting a carpet steamer and cleaning the bare plywood as best I can. The Sun's effect on it made me wonder if a heat lamp would not be a good idea. Maybe cook the remaining worst spots, clean the floor and let it dry and then apply kilz. I just don't want the smell to sneak back though.
Someone suggested shellac and BIN is white shellac. I looked at it and it $41 a gallon. Significantly more expensive than Kilz How can I know its that much better? Wonder how many gallons I would need? (Need a thousand feet of coverage.)
I am also wondering where else the smell is hiding. I am going to replace the ducts downstairs. Wonder if the whole house is just saturated with stink?
Any suggestions?
Re: Another Kilz vs. dog pee in stinky house question?
Nat Robison
I probably can't answer all your q's regarding the primers, etc., but the more the you post about this house, the more it seems to me that the answer is to replace the underlayment. I understand it's a rental and all but are you getting to the point (cost-wise) where it's better to replace? I'd hate to see you spend $500 trying to mitigate the smell (and still being left with urine-soaked plywood with a dozen coats of primer on it) when you could have replaced all the wood for $750.
Kneale Brownson
Again, shellac worked for me over 30+ years
Kneale Brownson
of cleaning up after renter pets.
Re: Again, shellac worked for me over 30+ years
Ron Jones
I know that shellac works for this. I don't have any idea about how the Kilz will work. But as bad as this one seems to be, replacement may be the only answer.
I replaced five sheets of plywood today. Also planning to replace the ducts downstairs. There are about five more I could replace.
The problem is that the pee ran under some of the walls. Without going to extreme measures like jacking the house up I can't get the plywood out from under the walls.
I think I will cut away the rest of the obvious stuff and replace what I can and then seal it. I am still wondering where else it might be hiding.
Ken Oakley-Sunny St. Cloud, FL
Maybe you are smelling your breath. It is the closest thing to your nose- eat some garlic.
What Kind of Shellac?  Cost? Coverage?
Gary Bindel
The urine may be in the drywall and baseboard. Cut a piece of the drywall that would be hidden by the baseboard, take outside and give it the sniff test.
Kneale Brownson
Re: What Kind of Shellac?  Cost? Coverage?
Kneale Brownson
I'd just buy shellac off the shelf at the paint store. If you're doing the whole house, I'd look into buying flakes and denatured alcohol.
Kneale Brownson
another thought
Kneale Brownson
I used to use two coats because the shellac temporary odor is so strong you can't tell whether to urine odor is covered or not until the shellac offgasses completely.
Bob
Bob
Sounds like you have a bad problem. I would not wast time or money on cleaning. Rip it out and start over you may end up doing that anyway. Peice of mind is worth the effort.
Re: another thought
Joseph Mulherin, sr
Considering all of the other guys responses..... I, too, would just cut out all of the floors and start over with NEW plywood underlayments, then add some good wood floors and shellac about three coats. You have said you have about $100K to play with so just do it....
