What's this hinge called?
andra
I built a table which folds in half, and I cant seem to find the hinges I'm looking for. I think it's because I don't know the name of them. I made a quick sketch so you know what I'm talking about.
These hinges, you screw onto the side of the table and they fold kind of like knife hinges, but opposite (if that makes any sense). They seem extremely strong, and almost industrial looking. I think they might be called like "inline" hinges, or "planar" hinges, or something. Anyway, I hope you can help.
Re: What's this hinge called?
Larry Barrett
Also called rule joint hinges. What you have drawn is a rule joint. The hinge actually fits under the table and doesn't look like what you have drawn, but allows the two leaves to fit together as you have drawn it. Good article in this months Popular Woodworking mag.
Sgian Dubh
They're not really the same Larry. A rule joint hinge (also sometimes known as a drop leaf hinge) has the appearance as seen below. Slainte.
Dale Lenz
Knife hinge
Re: Knife hinge
Sgian Dubh
Dale, a knife hinge wouldn't work in this case. Andra has a table where one leaf folds from an open position to rest on top of the other leaf when closed. In that circumstance there are really only two types that will work. The first is the card table hinge type. The second type that will work is a counter top hinge, sometimes known as a mangle hinge. Both allow the leaf to pivot through 180º. The counter top hinge type is visible on the top surfaces of the open leaves, and the card table hinge shows on the edges of the leaves.
A knife hinge (aka pivot hinge) won't work because it doesn't have a double knuckle as do both the card table hinge and the counter top hinge. The knife hinge type is appropriate for doors in cabinets, and there is a variation known as a cranked knife (or pivot) hinge to allow a greater range of swing in the door.
The drop leaf hinge also wouldn't work because it won't let the opening leaf fold over and rest on the fixed leaf. A drop leaf hinge also has unequal leaves making it visually odd looking. It really is a hinge designed for a drop leaf with some sort of rule joint moulding or fall flap moulding where the two leaves meet at the edge. Slainte.
Dale Lenz
Re: Knife hinge
Dale Lenz
Only looked at the pic, did not read the post. By their drawing it looks like a knife hinge. Going to in-laws for dinner.
Re: Knife hinge
William Duffield
Richard, I completely agree with your recommendations and critiques of the alternatives proposed. However, I think there is one other type of hinge that would work for this application, even though it's appearance and installation are completely different than what has been discussed up to this point. That is the SOSS invisible hinge.
Re: Knife hinge
Sgian Dubh
William, you are correct. I just didn't think of the barrel hinge type, SOSS being one maker of the style. Thanks for reminding us all of it, and thus widening the range of elegant and workable solutions to three. There are a limited number of contrived and inelegant solutions, such as using a butt hinge or piano hinge inappropriately, but they're not a good option. Even though they can be made to work they leave a knuckle sticking up in an awkward place when the leaf is open, and look unsightly. Slainte.
Re: Knife hinge
William Duffield
Thinking about the card table application a bit more after I posted, the barrel hinges have a disadvantage. When the table is open, they are completely invisible, but when one leaf is folded back on top of the other, the hinge mechanism protrudes from the edges of the leaf. A wealth of technical data is available on the SOSS website for those wanting to consider their applicability. Also, they can be a bit tricky to install.
The card table hinge you suggested in your first response is flush in both positions, and is of course period correct for traditional card tables.
