shellac spraying question
Jerry Gibbs
Got carried away spraying toner made with garnet shellac and transtint dye. the piece is now too dark. Can I lighten the piece by removing some of the toner layers with alcohol or sanding? Alcohol worked on a very small area, but on a larger piece, 6" x 14', I made a mess. My spraying technique is getting better, but my color matching needs work. Thanks. jerry
Re: shellac spraying question
Yes
Sanding it is my preferred method as you have more control. If, however, you want to take it all off and start over, alcohol does just fine. Trying to remove part of the coating with alcohol will just give you a bunch of blotches and lap marks.
Toning Tip: Dial back your material knob and use a wide fan to keep your spay mist as fine as possible, then apply with very light passes. Don't worry about a smooth finish as the trick is to get an even color. Top-coating with untinted product will smooth out your surface.
Re: Yes
Jerry Gibbs
thanks
PS
To check the color while sanding, wipe off the dust and do a light hit with a paper towel moistened with alcohol.
