I have the Powermatic 2800 *LINK*
Dave Paine
I had been considering the Powermatic 2800 and the Delta Model 18-900L
The Powermatic happened to be on-sale at Woodcraft and so I made the plunge.
The manufacture of the unit was moved to China, sad to say, but the build quality of my unit was good.
Despite the "cons" below, I have been happy with this purchase.
The variable speed design is two sets of cones with a spring arrangement. The lever changes the distance between the cones and hence the speed. So far working well. I thought I would get belt slippage, but so far not observing.
I did not research the Delta. It also has a variable speed. I do not know the design. I was interested in the Delta table design which tilts left / right and up / down. Since I never used it I do not know how rigid the clamp is.
Pro's for the 2800
Excellant chuck. Perhaps the best feature of the machine. Capacity is 1 - 16 mm. So goes from really small to just over 5/8in. Impressive range, but the build quality is even better. This is hand tightened, but I do not have to apply a lot of force.
Good size motor - 1HP. I have not had the motor feel to bog down.
Good depth stop - threaded rod style.
LED light is useful
Lasers are accurate, but sometimes the bit gets in the way.
Variable speed. Works well, easy to adjust so I actually use it.
Heavy castings. You do not want to need to move this once in place.
Large and rigid table with T slots. I use the T slots a lot.
The levers for operating the head can be installed on either right or left side.
Motor is quiet. The variable speed belt can be heard, but not noisy.
LED speed readout. I find this useful, especially to remind me if I install a large bit, but previously was running smaller bit at higher speed.
Con's.
Biggest gripe is the crappy too small screw for the speed adjustment. Large knob but inside it is 1/4in screw.
Second biggest gripe is no power off switch. The LCD speed readout shows "0" all the time. I had to plug the drill press into a power strip so that I could turn off the power for the unit when I am not in the shop.
Fence design. The dust collection got in my way to I replaced with Woodpecker DP3 fence. Much more useful
Table wing extensions held in place by plastic rings. I am afraid I could break these.
Plastic table insert with wide hole. I kept dropping drills through the hole. Finally I turned a piece of walnut to fit and no longer drop the bits through my solid insert. I like having an insert, I just prefer solid.
Rack for height adjustment does not go all the way into the head. Instead they have a collar which does not mount level. Works, but chinsy.
http://www.woodcraft.com/product/2020484/22531/powermatic-2800-18-variable-speed-drill-press.aspx
