There was some talk about scissor lifts
Gary Camp, Bend Oregon
Then Sophie stopped by and mentioned how handy his was. A couple of days ago our ski patrol was getting rid of a couple of hydrualic gurneys. The thought adjutable infeed or outfeed table popped into my mind. The have a foot pump and seperate controls for the cylinder at each end. Right now I have four 30" by 1" by 96 pieces of particle board (future bench top, also salvaged) resting on it. seems to be holding that weight jut fine.
glc
Re: There was some talk about scissor lifts
That should weigh just over 300#
Keith Newton
How much range of motion do they have?
Are you planning to stack all that PB for just one top?
I have outfeed tables for all my saws, but having adjustable height sounds great for assembly, and finishing, and even rolling out of the shop to deliver.
Re: That should weigh just over 300#
The lowest height is 29" with a foot or so of lift. It has very nice 1 lever locking casters and rolls quite nicely with that load on it. I figure if it is hospital equipment it should be good for at least 350 / 400 lbs. I have a 24ft wall that I intend to use for my old RAS and SCMS plus a 4ft or so vertical plywood storage, so I need a 20ft top. I suspect I will replace the old molded kitchen countertop I found on the property with something flat and strudier as well. Now I have free materail to use for the tops, tops I don't mind screwing stops or fixtures to.
