Wet Shop Vac question? OT?
I want to use my shopvac to clean up in the house I bought that has the worst dog pee problem I have ever seen. I am thinking of spraying the whole thing again with bleach and then slurping up the residue with the vac. Then maybe an application of vinegar and slurp that up.
(today we pulled out door trim and base boards where the dog had been lifting his leg and there were crystals there as if someone had spilled the contents of a slat shaker.)
So, if you vac up water do you remove the filter?
Re: Wet Shop Vac question? OT?
Stuart Johnson
Mine has a foam type filter used when using it to vac water and yes the paper filter is removed.
Dave Paine
Barry,
I definitely remove the filter, I also leave the drum open.
My logic is that I want to avoid mold growing in the wet and dark atmosphere of a wet shop vac.
The first time I ever used my shop vac for wet duty I did not remove the filter or leave the drum open.
The next time I went to use the vac, it generated a nasty smelling exhaust.
Keith Newton
Barry, One little trick that I have used when cleaning up a really nasty boat, was to maybe wet down with a super cleaner, then have a garden hose with a squeeze type nozzle to spray right beside the vacuum end fitting while I moved the two along together, to clean up the diluted residue.
I think vinegar works well, but you might check at PetsMart to see if they have something better.
Myra in TN
There is a product at pet shops, I believe it's called Nature's Miracle. It eliminates the odor of dog pee so well that other dogs can't even smell it.
Kneale Brownson
Forget the Vac, Get Shellac
Kneale Brownson
Shellac will cover that stuff up. Good to clean some first, of course. I never found anything that worked better in 30+ years of cleaning rentals.
TomD
You don't need any filter, foam or otherwise, to pull up water. If there is some dust at the same time, which seems like there shouldn't be, that would be a different mater. I have a goretex hepa filter on my shop vac which one could leave on, but for water I don't bother, because normally it is clogged with dust and would get kinda nasty.
I have to ask. Why would you buy a place that had the worst dog pee problem you have ever seen?
Ken Oakley-Sunny St. Cloud, FL
He bought it so he could ask more OT questions.
And the answer is....   OT?
Well, aside form my love of OT questions....
Normally, You don't get to go inside on these before you buy them. I bought this at foreclosure literally on the courthouse steps. Actually, this time I looked in through the windows and knew the place was empty, so I found a way in. (an unlocked window that I easily stepped through.) I know the carpet had dog pee and I wrongly assumed it would take the smell with it when we removed it.
When I net the other "pro" bidders at the courthouse, I was asked if I had looked at it and I admitted I had and talked about the pee smell and thought I was playing up how bad it was. Little did I know it was worse than I imagined.
This is about the fifth one of these (foreclosures) I have bought and fixed up. They all come with some "baggage". One of them had every piece of mail the woman had received since 1989. A thirty cubic yard dumpster (HUGH) full of debris we had to remove. Two of them had rotted out floors where toilets had been allowed to leak. We had to cut out floors and replace joists. Another has Cat Lady living in it. she has way too many cats and two collies. Without doing anything, I rented the house back to her. She has lived there thirty years and got in over here head with a second and then third mortgage. She can afford substantial rent, just not three mortgage payments. Someday, I will have to clean that place out and eliminate the pee smell, so this on is a learning experience for that one.
So, even if I have to cut out the subfloor and replace it and replace the duct work (they peed on the floor registers to the point they rusted away) this one will be cheaper to fix than those. I figure less than a $1000 worth of materials and Kilz. I am paying my son to help me and he is out of work, so that's a good thing.
The real answer is the house is a four bedroom two bath house assessed at $147,700 (Down from $165k three years ago). When the bidding opened the trustee announced it would start at $49,468.34. I rounded it up to $49,470 and no one else bid. So, I got a house built in 1993 with nearly a $100K "margin". And work for me and my son. And a challenge.
