A55 Smoothing Plane
Step 1 in chest of drawers
Bill Tindall
Well depending on how one counts it may be step 2.
Recall I am building a chest of drawers inspired by this Chester County PA piece.
Pieces from this period had either solid sides or frame and panel sides. I am going to make it with frame and panel sides. This construction offers some advantages that compensate for the added complexity of making two raised panels for the sides.
1. One can showcase an attractive piece of wood for the panel and I have some dandys.
2. Moldings are easy to deal with because long grain is being attached to long grain.
3. The case sides will stay flat. In the last piece I built I bookmatched the glued up solid sides. I put the most attractive side out. Humidity changes bow the case side in and that leads to bindy drawers in the middle where there are not top or bottom dovetailed tops and bottoms to hold the sides flat. It is a very annoying situation. I have planed the insides flat again when humidity bowed it in but it still is not perfect.
First I draw a small scale scaled drawing of the case side and front to get rough proportions right. In my hands the golden retangle never leads to a practical shape and this case was no exception.
the golden rule would make this case 48" wide, ridiculously wide for a chest of drawers of this size. This one will be 38".
Next I draw a large scale drawing for something like the frame and panel sides to get the proportions of the frame and pane attractive. In this case the bottom rail is widest, top rail next and the stiles the most narrow.
Today I attacked the tedious task of preparing an abbreviate cut list. I enter the data on the right side of the notebook. So for the top rail I calculate its length taking into account the width of the case, the width of the stiles , the width of the molding in the inside of the stiles and the length of the tenon. On the left side I enter the result-18". I like having the data used for the result handy for double checking for errors as I go along. So now on the left side I enter that I need 2 walnut top rails 4 3/4 x 18 x 7/8. I will eventually sketch a picture of this rail showing the machining needed to make the dado for the panel and the tenon.
I only prepare a cut list of the minimum parts to get the case together. In this example I needed to calculate the rails, stiles, drawer blades and the top drawer divider. ****All other parts measurements will be taken from the assembled case, dry fit in the case of the panels and after glue up for all else.**** Taking measurements from the case in hand eliminates errors and leads to precise fits.
Re: Step 1 in chest of drawers
George Colonel's Workshop-Havertown PA
Good Evening Bill,
I read your post with interest, and can only imagine how nice the chest will look when finished. The example is a classic, though slightly busy for my taste. OTOH, the proportions are critical, not withstanding the Golden Rule. I'm with you on that one! I look forward to following your every step.
George
Bill - keep us posted
Howard in Toronto
I think this post has a lot to offer by showing how design decisions are arrived at.
I appreciate you taking your time to post this info and will be very interested to watch your subsequent posts.
Thank you Bill.
Howard
