We value your privacy.
I am working on a project and when I drilled some holes in the pine I noticed that some of the wood around the holes broke off. In order to fill in the area that broke off what is the best wood filler to use?
In the past I have used plastic wood filler and it seems to work ok. But is there someting better that can be use on any type of wood? It will be primed and painted next. Thank You for your help.
For painted work Bondo works well on small fills. I've filled some big knot holes with it and found it didn't adhere too well for that (but these were 1"-2" fills). Never had a problem using it on small details like you describe.
I like the lightweight spackle. It dries fast, sands very easily. If it is in a spot where I think it needs to be tougher, I soak it with a little CA, which also dries fast.
I've been a Timber Mate convert for some time now and love the stuff. It is what I would use for something like you have because I have it in various colors already on hand.
However, if I didn't already have it and since you're painting, I'd probably go the cheap and simple route and mix some glue and sawdust up and fill the area. Once dry, sand and it's ready for priming and painting.
