fire retardent
fire retardent
fire retardent
mikemcnerney
I want to apply fire retardent to my existing 25 year old cedar shakes.
Anybody done it? What product.
I spoke with one of our local fire inspectors & he didn't know if I could?
MM
Re: fire retardent
Re: fire retardent
Joseph Mulherin, Sr
Mike, try contacting Flame Stop, Inc. They ship gallons of the retardent in various containers, and they are located I think in Fort Worth, TX, call i-977-397-7867
Re: fire retardent
Re: fire retardent
Joseph Mulherin, Sr
correction to number: call 1-877-397-7867
Re: fire retardent
Re: fire retardent
Nick Tuzzolino
Mike, be sure to get all the info you can on the life of the retardant. For real warranty, etc, it is usually applied to new, factory dipped shingles.
A few years back in Southern Calif it was found that late applied retardants lasted about a year.
Re: fire retardent
Stephen Shepherd
Re: fire retardent
Stephen Shepherd
Borax and water sprayed on will make the shingles fire retardant.
It also keeps the bugs away.
Stephen
Re: fire retardent
Re: fire retardent
Carol
Another thought is to check with your fire insurance company and see how your premium is affected by these shingles. Many fire insurance companies have a hefty surcharge for them. That coupled with only a year's worth of 'protection' may have you thinking about a new roof.
I have lived near wildfires most of my adult life, one that came within a half mile of the house. It is a scary thing. Very scary. When I settle in my next permanent home, I will be looking into tile or metal. Pricey, yes. More peace of mind, priceless.
Re: fire retardent
Re: fire retardent
John in NM
The most common method I know of is what Stephen mentioned - borax coating. That is what they do with cellulose fiber insulation. The idea is that the borax melts if there is a fire and forms an oxygen excluding coating over the smoldering material. Basically the same way it works as a hard soldering and brazing flux - keeps oxygen away from the molten metal.
The only trouble is borax is somewhat water soluble, which is probably why treatments don't last forever. Depending on costs, it may be worth considering replacement of the shakes with metal or tile.
Re: fire retardent
Re: fire retardent
mikemcnerney
So I have found the material but no one in Ottawa has ever done it or even heard of it done.
We have a 12 & 12 pitch so it means ladders or harnesses. The suppliers suggest one of those pump up garden sprayers.
Any further ideas on how to apply it. It's water thin but I think I prefer the idea of brushing or rolling it on. It seems very tedious.
MM
Re: fire retardent
Re: fire retardent
mikemcnerney
We have now decided to replace our roof.
Factory fire retardent shakes are $30,000
& some kind of regular fibeglass shingle is $14,000.
But a friend of mine pointed out that maybe fires, even in areas that are a lot more susseptable than mine, may not really spread from embers falling on a cedar roof.
Does anyone know or have a link to such info?
mikemcnerney
Re: fire retardent
Re: fire retardent *LINK*
mdclor
If you are going to replace the roof, consider a steel roof. They can be made to look like an architectural shingle so that should not be an issue. They are more expensive than fiberglass initially, but cheaper in the long run. You might also get a discount from your insurance company for having steel.
There are some good and bad examples at the link below. I like the one from KBS on the right of the third row.
FWIW
steel roof images
Re: fire retardent
I prefer steel too
John in NM
Though fiberglass would be ok I think. I would not replace with cedar, but that's just me.
All I know about cedar shakes and fire is that my old friend who was a hot shot 20 years ago said they didn't even try to save houses with cedar roofs, concentrating instead on those with metal roofs. Though anecdotal, that may tell you something about that theory of fires not spreading via embers on the roof.
