OT-WTB-GPS for my van
Tom Dunlap
My Garmin GPS has died. Now it's time to buy again. My guess is that someone might have a unit that had life in it when they upgraded. If you'd like to sell one, send me an email.
Thanks,
Tom
Re: OT-WTB-GPS for my van
What is yours doing
Dustmaker Mike
It might be fixable. What model was it?
Re: What is yours doing
Tom Dunlap
A Nuvi...I'm not sure which model.
I have it plugged into 12v. then I jiggle the connector going into the back. That makes the Garmin homescreen light up...which promptly goes black.
A few days ago it would light up the homescreen then I'd get a message that the battery was low. Within a few second it would go black.
This seems weird...what difference would the battery make if I have it connected to shore power?
My brother suggested opening the back and seeing if there's a button battery that might need replacing.
Any other suggestions?
Thanks,
Tom
YouTube the model you
Dustmaker Mike
Have and see what you can learn. With the loose power connection or maybe a bad connector on the gps I have an older 350 and the anntenna will cause the same problem so I have to open it up and tighten the wire connector if I can. You tube is your friend in this case
Jesper, Denmark
Jesper, Denmark
Sounds like a dead battery.
John McGaw
It certainly sounds as if the power connection is making and breaking since you say the startup screen appears then disappears. Could be a bad connector on either side or a bad connection to the printed circuit board. For sure, if the device is getting 12V to its innards it should start and run whether the battery is dead or not. Otherwise a device with a dead battery could never be charged.
Tom, I agree with the others that the power plug is not making good contact - could be on either end. If you have a light on the plug that goes into the cigarette lighter socket and it stays on you have an issue with the socket in the Garmin or the power cord. However you may want to look at the new Magellan and Garmin units as the price has dropped dramatically. My maps became so outdated on my Magellan it steered me into dead ends a few times, the battery went dead, and it was locking up once in a while (ran on windows CE). I looked into updating the maps and cost was around $80 for a one time update. I purchased a new Garmin for less than $175 with more features and free lifetime map updates every 3 months. My son bought a new Magellan at Best Buy a couple months ago for around $125 - also with lifetime map updates. Both of our units work somewhat faster, show the highway intersections more clearly, and are easier to enter addresses into - so some pretty substantial actual improvements.
