We value your privacy.
Ng has excellent camera presence and explains things very thoroughly. His five-cut method is empirically sound, but it seems overly complicated. F'rinstance, once you've cut your initial kerf in the base, why wouldn't you just put an 1/8" shim in the kerf and use an accurate framing square to adjust the fence square to the kerf? It would save a lot of cutting, measuring and calculating. You could test out your results with just three cuts, checking by eyeball to see if the fourth edge of your test piece was flush with the kerf. I guess the advantage of Ng's method is that it takes out the guesswork of dialing in the accuracy.
