OT 12 Volt PS
OT 12 Volt PS
OT 12 Volt PS
Dustmaker Mike
Howdy I am going to put a car stereo into my shop and was looking for an inexpensive 12V supply like they used to sell at Radio Shack. I have looked at E-bay Amazon and a few other places on the web. Any ideas on good used ones or new ones not so expensive ones?
Thanks
Mike
Re: OT 12 Volt PS
Cheap battery charger from Harbor Freight.
Re: OT 12 Volt PS
Maybe, Maybe Not
Bill Howatt
Cheap chargers may provide nothing but unfiltered, rectified AC and this will cause a lot of hum in the radio.
Bill
Re: OT 12 Volt PS
Re: OT 12 Volt PS
Tony - Memphis
I picked a cheap one on eBay that even had a cigarette lighter attachment and was regulated. Can't recall the vendor or brand. Make sure you get one that can handle the current draw of your stereo. What about using an old PC power supply? I made one into a lab power supply by making a box fo rit and hooking the outputs to posts. Works great. You can Google the subject and find lots of info. They are easy to find too. I snagged one out of my old pc. The pinouts are pretty standard and easy to find.
Tony
Re: OT 12 Volt PS
Re: Here is one... *LINK*
John McGaw
On the other hand, if somebody doesn't want to go digging inside of power supply where uber-lethal voltages live (s)he might go this route. I met the makers at Maker Faire in San Mateo in May and the product looks well-made and should provide enough clean 12V power for any car stereo (or ten).
Power Supply Breakout
Re: OT 12 Volt PS
Re: Here is one...
Carol
Thanks, John. I have a 12 volt linear actuator to supply. Now to roust a computer power supply. I know just who to ask!
Re: OT 12 Volt PS
Re: Here is one...
John McGaw
Hint: if you really want to draw huge currents from any of the outputs it will be necessary to change/bypass the protective fuse for that particular output. Not a big deal for an electronics type but I thought I should bring it up. If that seems like too much trouble the original hardware hack which adds terminals directly to the power supply might be the way to go.
Re: OT 12 Volt PS
Re: OT 12 Volt PS
del schisler
i don't belive a car charger will work. It is unfiltered and will have lot's of ac hum in the audio . some maybe better than other's i don't know. How about just getting a battery and chage it when it need's it. a lawn mower battery will be around the cost of a charger that may or may not work. the battery will work .
Re: OT 12 Volt PS
Actually..
Tony - memphis
No reason to go "inside" the power supply. All you have to mess with are the DC outputs. Nothing too exciting.
Tony
Re: OT 12 Volt PS
Ruled out the battery charger
Dustmaker Mike
It will be noisy and not effencent. I have a battery and a solar panel to trickle charge it I figured a low power supply would be all that was needed on cloudy days. Th ATX power supply hack looks like the ticket but for $14.00 the other one is winning.
