Re: I can answer that...
TomD
I build golf gear from time to time. My guess as to the time line is that drivers have just gotten too large. The heads are so large that these aren't your granddaddy's tees any more. At some point the tees get so tall that the waste factor is just enormous. The cup part is pretty constant in size and the longer you make the pin the more the waste factor gets worse. Also, you don't get a lot for tees, or necessarily the proportion to their extra size.
There are some great plastic tees, but they have their problems also. Many tees are either blasted down the course somewhere or pounded directly into the ground. They used to make biodegradable tees out of turf, but plastic you don't really want all over the place. Also, plastic often deforms, and the lips won't hold the balls so plastic may not get a lot more plays than wood. The flat plastic tees solve most of those problems but cost a lot. Etc...
Also, the wood in tees is pretty nice, if it had bad grain it would not be safe to press into the ground.
