spraying shellac question
Jerry Gibbs
I want to spray shellac in my garage with uncontrolled humidity. What should be the highest RH for success? Thanks.
Re: spraying shellac question
Q&A
If you're using a turbine HVLP gun, the RH can be higher because the turbine warms (and thus lowers) the RH in the air stream provided your receiving surfaces (what you're coating) are not cooler than the ambient air.
If you're running a traditional or HVLP conversion gun with a compressor, question becomes whether you keep the compressor and lines drained of condensate. If "yes" then you're probably safe to 65-70% RH. If "no" you can have issues at any RH because of water and water vapor in the air stream.
You can help yourself either way, by adding a drop or two of real pure gum turpentine to your mix as it will retard the alcohol's flash evaporation which can cause cooling of the surface and thus condensation of water vapor from the air to produce the blush you're trying to avoid.
PS
You can also help yourself by regularly draining the condensate water from your compressor tank and air lines. ;)
