Exterior Wood Shutter Design Question
Squints2See
Hello,
I am planning on building 3 sets of exterior shutters. 2 of the windows are 36" wide and the other is 32" wide. The windows are 6' tall. I am not sure whether I should stay true to the real shutter methodology and make the shutters half the width of the window or if it would look aesthetically better to make all 3 sets the same width. I am not going to have them operable but I am planning on using real shutter hardware to give them the authentic look.
If I were building a standard raised panel or louvered shutter there would be no problem because the center panel would not be anything distinct however I am using a custom design where basically the shutter is like a shaker style panel (standard rails and stiles) but with 3/4" vertical strips spaced a couple of inches apart to give a "mission" style appearance.
If I build the shutters to half the width of the window like the real thing, I can either keep the mission style vertical strips of wood the same spacing but only have 3 strips on the 32" window instead of the 4 strips on the 36" windows, or keep the number of strips the same but change the spacing of the strips as well as make the stiles a little narrower. However I tend to think it would look better keeping the proportions/spacing the same and having one less strip on the smaller window.
The other choice would be to find a happy medium width, and make all three sets the same size (say 15-16" wide). But this would not be the proper way of doing it.
Any thoughts on which way I should go?
Thanks,
Todd
