OT - shimming studs
I'm in the midst of a remodel on our old (1892-95) house that has included reframing a wall (and will include reframing more walls). The post-war framing on it is slightly larger than current stock - nominal 4" stock is 3-3/4" or so, but variable.
I've held the stock to the inside, and am now facing up to shimming the new studs on the outside to get a fairly flat wall. The trouble is in the variability - one corner post, for instance, ranges from 3/8" to 3/16" wider than the 2x4 face-nailed to it.
On entirely new work, I'd probably just nail it all up and then bring things into line with a power plane. But the old framing in this case is littered with nail heads and such that would wreak havoc with the carbide cutters on my plane.
I'm considering ripping shims to the thinnest dimension needed and making up the difference with a thicker/thinner bead of construction adhesive. Any other or better suggestions?
