Drilling pressure treated lumber
Howard
I need to drill 1” dia holes through 6 by 6” wet pressure treated lumber using a hand drill. What is the best type of bit to use? Need to drill 15 holes. How hard will it be to accomplish?
Thanks
Howard
Howard
Thanks
Howard
Re: Drilling pressure treated lumber
I always use a spade bit. You can make it through a 4 x 4 easily. For a 6 x 6, you may need a longer bit or an extension.
Re: Drilling pressure treated lumber *LINK*
Dave Paine
Your challenge is big diameter and depth.
Ideas which come to mind :
a) Brace and bit. The old spiral drills for brace and bit were made in this diameter and if I recall longer than twist drill. Take a look at garage sales, local flea market. There is an "antique and collectables" store down the road from me, which is where I would start to look for this. They have the braces, likely many of the bits.
b) Not cheap, but the Colt Maxi-Cut Forstner bits will drill through this the best. They also sell a really neat extension which twists in place and does not slip in use. Use can always try drilling from one side, then flip and drill from the other side. Not sure if any misalignment would be an issue.
The Packard link below is the header. Cannot open the next page for some reason.
c) Spade bits are also readily available. I personally hate using these, too much vibration, but it may be the only available inexpensive option.
d) Twist drill, again look at flea markets. Either need an extension or drill from either side.
I purchased the Colt Maxi Cut Forstner bits for drilling pepper mill blanks. I have used the 1in dia bit. It cuts better than any other Forstner bit I have used.
http://www.packardwoodworks.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=packard&Category_Code=drilling-bits
I would do this with a spade bit and would have done it without much thought. I like the old version without the spurs because I can sharpen them easily and quickly on a grinder or with a file.
I also have a Greenleigh (Greenlee?) "electrician's" bit. A single flute spiral bit with a lead screw and if it were the right size, it would make short work of these holes with a half inch right angle drive drill twisting it. I'd have to look at mine, it maybe a 7/8". One this size would cost $30+/- at Lowe's
Installer's Bits
Available at [real] electrical supply stores will do this nicely with a power drill. They come in lengths from 12" to 4'. I use a 3/4" diameter example to drill hidden wire paths up through 4x4 PT deck railing posts. I do, however, use a 1/2" corded drill [Milwaukee].
If you're doing "real" hand work, a brace and bit combo would be the tool of choice.
Mostly agree.
Jason Roehl in Lafayette, IN
The self-feeding auger bits are the bee's knees.
The only thing on which I disagree with Barry is that I LIKE the spade bits with the spurs on the outer edges of the wings. But I wouldn't hesitate to grab a 1" spade bit of any flavor and just get'r'done.
Too many more replies, and you'll spend more time reading than the difference in time between the quickest and slowest (powered) methods.
Jason
Jason Waters
A spade is the cheapest. And will work. For these limited holes, may be the way to go.
A Ship Auger would work well (that's the spiral looking one with a lead screw).
Then there is the sel-feed bit by Milwaukee and others, though you may need and extension for it. This is typically the most expensive, though would make probably the cleanest hole.
I personally would use a ship auger if I had one (I have about 5 or 6 various sizes) and a spade if not. Otherwise, break out the bit and brace and do them by hand because I have a full set from my grandfather. Got any children or grandchildren to teach how to use a bit and brace? They love using them.
Jason
Ship Auger Bit
Jason Waters
Here's a Ship Auger bit:
http://www.irwin.com/tools/drill-bits/speedbor-ship-auger-bits-with-weldtec
If you ask the guy in the tool section where the ship auger bits are and he doesn't know, he's probably not the guy you want to give you drilling advise (that's my opinon). Even Lowes and HD carried them last time I went looking for one (might have been a couple years).
It's what I would pick first. Probably $10-20.
Electrician w/ship-awger almost killed my helper,
Keith Newton
Back around 1970, we were building a house in Bella Vista, on a steep hill. We were up about 40' on the back side of the house on a single 2 x 12 scaffold board on wooden legs. We were hanging soffit board overhead. Just as we lifted the material into place, about to drive the first nail, my helper on the other end of the board let out a scream that I though was the beginning of him falling off backwards.
My hair still tingles when I remember that blood-curdling scream. But when I looked over, there was a ship-awger coming out through the wall, into his crotch area. It didn't even break the skin, but had grabbed the inseam of his jeans, just below,,,,,,,,,, uh,,,,, the family jewels, then wound around the bit, tearing out a big swath of fabric.
The electrician was so shaken, he lost his breakfast. He was just starting to put a outlet box, which would be over a deck, yet to be built. It just didn't occur to him to look out the door before he drilled.
To answer your question now. The ship-awger would be my choice too.
WOW!!!
Dale Lenz
What a story, Keith....not to make light of the story.........the ol' saying "caught between a rock and a hard place" came to mind.
Thanks for sharing
