Grizzly Table Saw Fence
Tom Rex in TX
I have a Grizzly 1023Z Table saw with a Shop Fox fence that I purchased in November of 2000.
I'm having trouble with the fence.
I followed all of the directions that came with the fence but I can’t get it adjusted correctly.
To make it stay where I set it I must put a clamp on the back of the fence.
If you have had this problem with this fence how did you fix it?
If I were to replace the fence with another brand what would you recommend and will that fence fit on this Grizzly?
Thanks in advance for any and all help,
T Rex
Re: Grizzly Table Saw Fence
Jason Waters
Did the fence just start this issue after 12 years?
I take it that it is a Bisemeyer clone? If it is, it's a good fence and you shouldn't be having issues unless a weld broke or something is worn out.
I think something is wrong. Is the head assembly properly placed on the front rail?
do you have some pictures?
steve mackay
My Shop Fox won't clamp once I've run off the table and onto the wings. It's not meant to so I just use shims for that. The "leaf spring" on the inside guide might be too "flat". You can "open" it carefully, but don't be to agressive and break the weld. My beef is those Teflon pads. I've had them fall out and not notice it. I cuss and swear untill I find one on the floor and realize what happened. I understand the reasoning behind the pads but just don't think much of them. All that said ,try re-setting all your "allen" adjusting screws. Once they get moved to one extreme or the other the is trouble. All the way out and it clamps too tight (the lever won't go down), all the way in and theres not enough clamp left.
Herb Wofford
My General 350 came with what I thought was an original biesemeyer, but late found out it was a clone. Mine after awhile would not stay clamped, so I called Bill Biesemeyer and that is when I found out that it was a clone by permission from him. He told me to glue some plastic laminate strips on the part that put pressure on the rail. I did this and have had no problem for 20 + years. Hope this might help.
Herb
