After market spliter
Bob
Bob
I have a Delta UNISAW the splitter and guard are garbage so I would like to get a newer one that does not bend and deform I saw one once that looked lik a shark fin and had a pair of anti-kickback cams that worked from the sheer weight of them. Anyone know where I may get one?
Re: After market spliter
Al Stokka - Cambridge, Iowa
Good morning Bob,
I recall a post from Badger Pond (likely from Mark G.) that Delta sells their splitter two ways; as a part (replacement) and as a kit. One of those was vastly cheaper, but I can't recall which, AND, as "Badger Pond" implies, the post was years ago and Delta may have caught on.
I have the kit number as 78-431, Anti-Kickback, Snap-In Spreader. This info is from October, 2007.
Hopefully, someone with a better memory than mine will post regarding which is cheaper and whether Delta has equalized the prices.
I have this splitter on my saw and it's a joy to use.
Al
Re: Add'l info: After market spliter
Bob,
The splitter carries the name and item number "Biesmeyer 78-431".
Al
Jason Waters
There is the Bisemeyer, and there is the Uniguard splittle. The Bise uses a pin to install and remove, the Uniguard a thumbwheel.
Here is Mark's site, and while it lists a price, don't expect it to be the same now!! It's been over ten years:
http://www.happywoodworking.com/Uniguard.html
I've used the Uniguard splitter on my JET cab saw for over 10 years. While it's not a riving knife and must be removed (easy) for non-through cuts, it's done a good-enough job. I took off the silly kick-back pawls. They tend to scratch the wood, and, if your fence is properly adjusted, they're mostly useless anyway IMHO.
Speaking of Mark...
John E. in SC
whatever happened to him? Used to enjoy reading his posts, but haven't seen him here in a long time.
Re: The Shark
mdclor
I have the Sharkguard for my PM66, but without the kickback pawls. It is great for dust collection and is a quality product. However, be prepared to wait for delivery if you order from him. My experience was that delivery took almost 3 months IIRC.
Re: Here is one
Jason Waters
That's the Uniguard splitter, the one I have, and the one shown on Mark's site.
It's a good splitter for the price.
Robby Wright in San Marcos, CA
Bob - I have the old contractor's saw and had the same problem you had. I bought a used Biesemeyer spitter setup and removed the pawls as they were worthless and kept jamming my wood. That worked pretty well, but I wanted something better. I liked the "pull the knob to release" feature, but didn't like the splitter.
I bought replacement splitters for the Shark guard - just the splitters. The link was listed earlier. He made them to my measurements - I asked for a .105 thickness. Great splitters. The setup woriks like a champ.
Bob
Bob
Thank you one and all. Now that I have installed my out feed table I HAVE to get something there for safety I think I will look into the shark and order this week.
Thanks again.
Re: The Shark
Jerry Gibbs
I like the dust pick up feature of the Shark. It is easy to remove for through cuts. The pawls were a waste of money, but not much. Jerry
