200+ woodworking book reviews
OT Questions on removing Pet Odor
Looked at a potential investment property today. It had the worst pet stains/odor I have ever experienced. The plywood under the carpet was dark brown/blackened. Mold was living on the floor. apparently dogs lived freely in the house for a long time.
Any Idea how to remove the odor? Permanently?
Re: OT Questions on removing Pet Odor
Dave Paine
Barry, the typical method for mold is bleach.
The typical method for urine smell is vinegar.
Neither of these may work completely for this situation.
Consider sanding the plywood, and then applying a product like Klinz over the plywood to seal in the odor. A last ditch solution since you are sealing and not neutralizing.
Good luck.
Carol
OK. Been there and done that.
Bleach the stuffings out of it. That will kill the mold and some of the odor. After it is VERY dry dump shellac on it by the gallon. You will have sealed off the air from the mold and sealed the odor in. Remember to ventilate, ventilate, ventilate and where bullet proof respiration protection. Air out the whole thing for a couple of weeks. Then again, you could also rip off the plywood and re-sheet it with new. Might be the easiest.
I had a house with concrete floors (Arizona), same problem. The above worked.
But a question comes up. Dog urine and mold? Sure there isn't another leak somewhere?
Carol
AARGGG! ...wear, not where. Mia culpa.
Rob Sandow
I would rip out the carpet and plywood and replace both. If this is not possible, rip out the carpet and saturate the plywood with Nature's Miracle Urine Eliminator (they have different formulations for cats and dogs so make sure you know which it was). This stuff really does work. Once that is dry, if there is mold or mildew, saturate it again with bleach. Then sand (use a respirator) and apply a shellac based primer, BIN or SealCoat depending on whether you need a clear primer.
Carpet is toast; goes to the landfill.
If you can economically replace the ply, do so. Otherwise a enzyme neutralizer, followed by chlorine bleach, then sealed with a shellac-based stain kill (2-3 coats) might get the job done.
+1 on Nature's Miracle. It works well. However if it is this bad, consider replacement of the offending plywood.
Ken Oakley-Sunny St. Cloud Fla
Lock a skunk in the house for a week.
Hal
LOML says vinegar/water solution.
