Losin' It?
I spent years learning to hand-apply finishes to wood. From French Polish to drying oils, I worked to create those lovely, rubbed-out, coatings that give one the tactile response available nowhere else (outside of the bedroom
Then I discovered waterborne finishes.
Then I rediscovered spray application by that new-fangled H-V-L-P method.
So SWMBO (and me) decided to replace the sliding doors out to the deck, and ordered the units in (inside) bare wood to finish to match the existing (stained/poly) woodwork.
Stain goes on OK, other than the crap wood used by Andersen, but when it comes/goes to applying the poly (oil-based, thank you) top coats? Drips, runs, sags,misses!! Yikes! I can't run a f!@#$%g paint brush anymore! I used to have the ability to put a glass-smooth finish on a boat hull or entry door, but that seems to have evaporated.
I think I should mourn the loss.
I'm not sure though.
Perhaps a couple of ales will assist . . .
