OT Anybody tried gluing a Plastic Chair?
Friend of mine bought a couple of the molded plastic chairs at an auction and one of them is broken. Though it was made of PVC and tried plumbers glue...nothing, did not touch it, zip. Turns out it is marine grade polypropylene. Anybody know a glue that will work? (I know the chair is cheap junk, but my pack rat gene has kicked in.)
Re: OT Anybody tried gluing a Plastic Chair?
Dave Paine
Worth trying epoxy. Rough the surface with sandpaper then clean with acetone.
You do not state if this is a cosmetic repair or structural. I hope the former, although epoxy and fibreglass mat should work.
I did fibreglass mat with epoxy to fix a plastic cannister vacuum handle where the hose attached. Still holding.
I am not sure what type of plastic was used, but the first attempt with just epoxy did not hold.
Good luck.
Yes
But found out the hard way that PVC cannot be glued with anything like a reliable, weight-bearing, bond.
I therefore "glued" the piece to the recycling bag and took the whole lot to the transfer station recycling pile.
Ken Oakley-Sunny St. Cloud, Fla.
Probably the glue is worth more than the chair
Gary Camp, Bend Oregon
A good ski shop may be able to repair it with a base welder. I know there are hot air plastic welders around I've never tried finding or using one. Can't imagine it would be as hard as Oxy-Acetelene, although I'm sure it would cost more than the chair is worth.
Leo Cuellar
Leo Cuellar
Another thing to try, is drilling a few holes on each side of the break, Barry, and zip tie it together. Will work for a while.
Agreed
Nat Robison
We're talking a white $10 chair from Walmart, right? I'm all for repairing and re-using but I wouldn't think much of getting rid of or recycling this chair......especially if the damage is in a weight-bearing area.
