We value your privacy.
Hole saws have "set" teeth they create there own clearance it is the sawdust the binds the plugs up.
Work the saw in and out to clear the dust especially toward the end of the cut, cut the final little bit from the opposite side if possible. If the hole size is not critical work the saw side to side to slightly enlarge the hole for an even easier ejection.
Tom, Even worse than that, is the fact that they have too many teeth, and too much hook to the teeth. You do good to get 1/8" per plunge, before needing to come up to clear the teeth.
You can do like I do, and take it to the grinder and grind 2 of every3, or 4 of 5, giving it a big deep gullet that will get you all the way through a board in a lot less time.
I found this out by sharpening dull ones. But then after that, I will go straight to the grinder with a brand new bi-metal right off. Also, the arm breaking grab can be eliminated by bringing the hook back to zero, or negative a few on the ones remaining. It only takes a couple of minutes on a grinder with a 1/4" wheel.
The grind they use is wonderful for materials like cast-iron. But I wonder if they know how many woodworkers and plumbers fight these beast daily?
I use mine to cut out wheels (just the cnter) 'bout 80 - 100 at a time. The weapon of choice is a walnut pick with the point bent back. Stick it through the slot in the side, half turn, stick, etc, etc. I've eyeballed those fancy "ejectors" from several makers. They all look like they would take up too much of my thoat on the drill press. (Either that or I've just gotten my system down to where I can go-fast !)
Could you loosen the set screw, remove the drill bit, then run a screw into the center hole and pull the plug out by the screw? I dunno... maybe too much effort?
Get down on the floor with a BIG hammer, a punch, a beer, lots of swear words, beat the hole saw to a pulp, drink the beer. Then, go buy the new Lennox blade.
My Dad taught me to drill from both sides with spade bits and hole saws.
I have a screwdriver with the about a 3/4" 90 degree bend in the tip. I used it to shoehorn the windshield gasket into a pickup. This works about as good as anything for popping the plugs.
This may not apply exactly, but it's a good trick so I'll try and describe it here. If I can get a JPEG to post I'll do that too. We'll see.
I saw this online somewhere, but I can't remember where. Nor can I take credit for an original idea.
If what you're after is a large hole and not the plug itself, as in making wheels or such, this works very well. It eliminates a lot, if not all of the stopping and starting to clear the dust from the kerf. The dust that burns so well.
Start the hole saw to mark the location of the kerf. Then drill a hole just inside the kerf, tangent to the kerf, which will act as an ejection port for the sawdust generated by the hole saw. I'd say the bigger the hole the better. It probably relieves enough tension to help release the plug too. Obviously this won't work in each and every situation, and I'd hate to have to do it 100 times over. However, it can be a big help.
