Drum Sander Noise
Doug Reynolds in Seattle
My Performax 16-32 conveyor belt motor is making a lot of noise. Is there any maintenance I can perform on it? Is it fairly user-friendly to replace if need be?
TIA, Doug
Drum Sander Noise
TIA, Doug
Re: Drum Sander Noise
Dave Paine
Noise is normally a sign of a bearing needing to be lubricated. Could be bearing in the motor, or bearing in the rollers.
See if you can isolate rollers vs motor.
The motor should not be difficult to replace the entire unit, but I have not looked into trying to replace the bearings.
It will be a bit of a pain to have to remove the conveyor belt then the rollers to finally be able to remove the motor.
First thing is to try an lubricate any bearings you find. Blow out with compressed air first. For some reason drum sanders generate dust which can get everywhere.
