Re: Rocking chair rockers
Joseph Mulherin Sr.
Rob, am glad someone viewed the website I mentioned about the rocking chair.
I plan on building about 12 of the chairs for family members and a few friends....just got started yesterday on gluing up the back braces.
In building the rockers you have to make 1 1/2"x 3/32" wide lams on the table saw...say about 48".
Copy the form of the old rockers...make a MDF form to match the shape...screw on 1" aluminum angle irons so the lams when glued up and installed onto the forms are alined on one side. Squeeze down you clamps(I used pipe clamps and quick clamps on ends), use Titebond glue, let to setup for at least three hours. Romove them and scrape off the squeeze out glue and them shape the rockers to the form of the old rockers with your ROS or angle grinder flat sander. In making the rockers where they attach to the legs, make some 10" pieces of the lams left over you can cut off after glue up, place them where the legs meet the rockiers, mark the place with pencil, then turn over and glue the pieces to the rockers and use a long screw to attach them. Then shape a smooth transition from leg to rocker, the stain or paint as needed.
Good luck, Joe Mulherin in Indio, CA
