We value your privacy.
"Black and red squares, stained so you could see the grain of the wood."
I can work with veneer or solids for the squares. I suppose if the woods need to be stained I'll need to do each species separately,seal with shellac then glue up.???Looking for a good direction on this-
The last one I made was walnut and maple, 1/8" thick squares, forget the other dimensions, maybe 1-1/8" or so. The grain alternated so as to cut down cross-grain expansion, and a slight gap the thickness of a piece of paper was left between each piece. In addition, each piece was beveled at a 45. The idea came out of a Woodsmith magazine of long ago. They were glued to a BB plywood substrate, 1/2" if I remember right. You are well aware of the humidity extremes in ND, and there has been absolutely no problem with warping.
I'd be inclined to make it with all maple, dyed or stained red and black and let it go with that.
If the client is expecting to see "grain" then maple may not be a good choice.
I have only made two chess boards, but without staining, so I used maple and walnut.
If the client wants black and red and to see the grain, I would use a wood which can easily be dyed or strained and has some grain pattern. Perhaps ash or hickory, something with grain, but naturally light.
Should be easy to make either of these black or red.
After I had made my boards, I read a good tip. Instead of making a slab 8 strips wide, then cutting and flipping alternate strips, make the slab 9 strips wide then move alternate strips over by one. Helps if the pieces were not exactly the same thickness - which happened in my last board.
If I were making it for myself, I would consider redheart or padauk and (macassar) ebony or wenge. Then there would be no need for staining. There wouldn't be much material used so the cost wouldn't be prohibitive.
In any event, I would like to see the finished product.
Firstly, I would never use an open grained wood on a chessboard. Secondly, you did not say what your client means when he says he wants the grain to show. What kind of grain or figure? Narrow stripes? Pommele? Burl? Does he want the same wood and/or figure for both color squares or two species? Does he want a classic chochineal crimson, a cardinal red or a deep reddish burgundy? I ask because you may wish to match the set intended for play upon the board.
I've played on a deep carmine board with a slightly brighter 1920's Rouge et Noir Regency set that balanced well. These things may be very important to some chess players.
Of course, as a red and black board is not regulation, unless agreed to by both players and tournament director, it can, for casual play, be just about anything the client chooses. Ebony of uniform figure is always tasteful for the black squares paired with dyed burl for the red squares and not uncommon before the Staunton era.
I've seen some striking boards of dyed burl, ebonized black squares with crimson reds. Also, unlike other boards in dark and white squares, a very fine strip of contrasting material between the squares really sets the board off where both colors are deep and dark. It can be another wood, ivory, high karat gold or fine silver (both resistant to tarnishing) or some other material.
Since your client stipulates the wood figure be visible, I'd use only aniline dyes. You can dye your own squares, whether solid or veneer, or you can purchase veneer already dyed. These veneers are usually dyed throughout so you will not sand through and expose the undyed color. The problem is, however, that the figure on such veneers may be disappointing compared to more luxurious burls.
At any rate, dye, dry, re-dye, sand away any raised grain and repeat until desired saturation is achieved. On some woods it may be preferable to raise the grain a final time with a heat gun (lightly), then dewhisker, especially if your wood is walnut or similar. As a final touch, I like to burnish some woods for best effect. It can resemble an aged patina that I find pleasing.
By the way, I'd dye even red species as most will eventually lose their intense color and change to browns. Most importantly, test your finish to make sure it does not cause the dye to bleed or spread to the adjacent squares.
You may also find that sanding can cause problems, even after shellac's applied. I generally do as much as possible to minimize final abrasion, favoring a very sharp card scraper with a fine burr or no burr at all to avoid problems. Sometimes I'll use single edge razor blades right to the edge of the squares to keep bad things from happening. Test test test.
Even though the board may not be for a regulation set, you should keep in mind the scale of the chess pieces. If the set is regulation, I'd suggest regulation 2 1/4" squares, but with particularly large sets 2 1/2" squares are not uncommon. The general rule for best proportion for irregular sets is to choose a square size that is 1.25 to 1.3 times the width of the king's base, although I prefer somewhat larger personally.
I realize that was a sweeping indictment and generalization. I thought about fleshing that out by saying some open-grained woods can work if the wood is well chosen and the grain properly filled and finished. Walnuts and some mahoganies can be used, of course. If the grain is left unfilled and the finish is thin or in-the-wood, dust works into the grain and is unappealing and even distracting.
So it's really about playability and my own aesthetics. I find open-grained woods to be particularly unattractive, especially when used on the light squares. Ash, oak, and so on, are particularly distracting, even when bleached. I've made by share of traditional boards and have usually used sycamore or maple for the light squares. Both hold up well to that particular breed of player who like to place the pieces hard upon the squares, or even worse, those who firmly screw them into place. Some chess players are very odd indeed.
As a long-time tournament player, quiet woods with little to no figure are to be preferred over striking, contrasting and highly-figured woods. Many players, including me, will protest and refuse to play on a distracting board, even if the squares are regulation size. Also, any board with a glossy or noticeably reflective finish is dead out. So while I enjoy it on other surfaces, French polish on chess boards simply won't do unless knocked down to a fairly non-reflective matte. For casual play or home use? Go right ahead. The famous Spanish 16th-century priest Ruy Lopez used to counsel his students to place the board with the sun in his opponent's eyes.
I should probably reinforce that I wasn't saying others shouldn't use open-grained woods, but that I would never. The one exception was a player who insisted on Japanese figured ash (tamo) for both the light and dark squares (which were dyed a deep brown-grey). It was beautiful but wouldn't be something I'd choose to play upon. I also remove any figure or color variation in the white squares by bleaching.
I should admit I'm much happier studying and playing on the standard regulation green-and-white roll-up mat. I have several wood boards and a table but still prefer the roll-ups. It's a sight-of-the-board thing. My favorite wood board is black and grey, by the way.
I also make go-bans. The last two floor go-bans were for one client. One was thick eucalyptus veneer, bleached bone white then dye washed in a pale dove grey with oxidized silver strip inlay lines. The other was a pale salmon wash with bead blasted stainless steel inlay lines.
For the pieces, every player should have at least one regulation Staunton design, but there are some very interesting modern non-turned designs and I rather enjoy some of the more elaborately turned antique sets that preceded the Staunton era. If you're considering turning your own set, Mike Darlow's book is a good place to start.
Don't know what the budget is, but some of that impregnated wood they use for pens, in red, if you could find it, would be great. It really holds the colour and the burl has spectacular grain.
The red dye I have used from LV does not hold it's colour. Great on stuff like arrows that one throws out, but it does not hold up longer term. There may be some that do, but I wouldn't know until it is too late.
By the way, box elder burl does have read highlights in it that are like blood, but just in spots. I haven't seen a big piece, but at least it make the idea of red BE seem less preposterous.
I read most of the responses, but I still may have missed this suggestion. So if this is a repeat I apologize.
If he really wants red and black, you could use red and black veneer. By that, I mean veneer that's been dyed red and black through and through. The color is part of the veneer as the veneer was dyed under pressure so that it permeates the thickness of the veneer. I can't recall if the entire log is dyed and then sliced, but I suspect that's the case. A little research would find that out quickly I'd bet. Red and black aren't the only colors available. I believe dyed veneers like this are frequently used in marquetry packs.
I've used the black dyed veneer quite a bit but never the red. I will say that the black dyed veneer isn't real strong on figure, or grain. It doesn't look painted, but it is pretty bland.
The thoughts of prestaining, sealing and then trying to assemble a chess board without cutting through the finish somewhere gives me the willies.
Of course, that's if the client is thinking red ... as in fire engine red.
Since you seem to have some experience with making chess boards, I'll pick your brain a bit.
How does one prestain and seal the material, and then assemble and level all the prefinished material without ruining all that prestaining? As I said ... the idea just gives me the willies.
Do you have a web site that shows any of your boards?
On a project this small, trying to save material cost is stupid. There are only about 4 sq. ft. to a board. If you use a veneer valued at $10 per foot. it would be worth it on the back end.
I would use ebony and bloodwood. Both are dense, color-fast without the smudge factor of a soft light colored wood. Just lay them up, sand and finish, without the worry of the black going down into the tissue of a lighter dyed wood.
