Post office box bank question
Bill Tindall
Are the boxes typically mitered. Will just a glued miter be sufficient. If a spline is desirable how does one make a spline that doesn't show on the front (a "stopped spline").
Re: Post office box bank question
Dale Lenz
Dale Lenz
Bill the ones I've seen, maybe 2-4 of them maybe, they are either box jointed or dovetailed. If I was going to miter the joints I'd use the showy "splines" actually the keyed feather like on my flag cases.
Your Choice
Tony - Memphis
I bought one when I was a teenager and it appears to only be mitered. I doubt they did any fancy splines on it. I made a couple for my brothers (I worked at a college Post Office - up your way - think orange - and was given a few of the old ones) and I just used miters with no splines or anything. I may have added glue blocks on the inside - can't recall.
Tony
A.J. Hamler
A.J. Hamler
A glued miter joint on one of those banks will be more than sufficient and plenty strong. They don't take much stress -- they spend 99.9% of their life sitting on a shelf -- and the risk of the joint not being strong enough is almost nil.
I make a lot of these, and I use a combination of rabbets and doweled butt joints. I rabbet in the bank bottom as well as the back panel (that alone would be strong enough to drop it off a house onto concrete and it would survive just fine), and butt-joint the top on and run dowels through the top. Then I arch the top, keeping the dowels visible for interest. Visible splines with miter joints would look nice, too. Here's what one of mine looks like:
One thing to keep in mind is that you have to create your opening carefully for the door to fit properly, which means if you're going to do miter joints you have to measure exactly, and always do a dry fit with the door before getting out the glue.
A.J.
thanks everyone
Bill Tindall
All good advice and ideas. I like the domed top, most attractive of the designs I have seen.
Re: thanks everyone
This would be an easy job for a biscuit joiner, but I think it would not be necessary.
Re: thanks everyone
Bill Tindall
I own one but never had much success with it. It is enough to make one become a hand tool enthusiast (well almost).
Bob
Bob
http://lumberjocks.com/closetguy He has it down pat/
Plans available
James Fox
Perhaps A.J. is too modest to mention it but he wrote an article with plans for the boxes in the first Woodcraft Magazine, published 05/01. A.J. has also included an updated set of plans & instructions for making the banks in his book, "Box Builder's Handbook."
I've made about 30 so far and given away all. They all seem to be enjoyed by the recipient. Thanks, again, A.J.
James
A.J. Hamler
Re: Plans available
A.J. Hamler
Glad you liked the box, James. You've made 30? You'll be catching up to me soon.
And thanks for the book plug!
A.J.
