Re: Engineered Hardwood Flooring???
NickinMass
A few thoughts:
Moisture coming through your slab is your biggest potential issue. Do a calcium chloride test to see how much of a problem you have. Alternately, you can put down a troweled on moisture barrier (but they are spendy, so I think it is worth doing the test to see if you need it).
I love the way bamboo looks (especially vertical grain), but I agree with the previous posters that you need to be careful of the quality. My impression is that the good stuff is just as expensive as hardwood.
Have you considered a floating installation isntead of glue down? If you do, and you do it yourself, make sure you have a deadblow mallet handy for snugging up the panels (learned that the hard way last summer - a regular hammer/mallet bounces and is not particularly effective).
I did a walk-in closet with engineered cork flooring (floating installation) - I don't think I'd recommend cork for a living room (its kind of soft and I'd be concerned about dings), but it looks great and feels fantastic under bare feet (and stays warm too, even over our unheated garage in Massachusetts). The floating installation worked out well too, although I still need to install some of the shoe molding...
