Garage/Workshop walls?
Joe Pack
Time to consider interior wall material (or not).
My new building will have a 28x28 garage area. To install an interior wall or not to install? If I do, I will insulate the wall, just in case...
I will also have a 16x28 insulated shop room that will have finished interior walls. Most likely choices of wall material are drywall or OSB, based on cost. I will use several sections of 1/4" pegboard, but plan to build those seperately over 2x2 frames to keep peg hardware out of contact with the insulation. What do you see as pros and cons of these. Is there a better, fairly economical choice for workshop walls?
Re: Garage/Workshop walls?
Pete in Holland
7/16" OSB. Pretty cheap. Not necessarily pretty though.
Great for screwing light/medium hangers/shelves/brackets to. Withstands the shop enviroment much better than drywall. Quicker too.
OSB also absorbs sound a little bit better than drywall, which does a good job of reflecting it.
Hang, prime with oil based primer, then paint white or off white with a semi-gloss latex paint (easier to clean than flat). Failure to paint will allow it to continue to darken, and require more lighting up front, and increasing down the road.
Drywall is for living rooms. It's a shop. Uniform installation of the OSB, along with a nice paint job, will make a nice wall. Mine is mostly covered with cabinets, fixtures, clamps, display boards, pictures. Your eye is drawn to that stuff.
Pete
TomD
I have drywall and it ads value to the shop, is more fireproof, and is fun to do, if you like that kind of thing. I live in a cold climate, and one problem with drywall is that it is always cold. I have my doubts about insulation, what really seems to mater is whether the material is cold. I have a lot of thermal windows but if you put your hand on them they are all somewhat cold, therefore if you have enough windows the room is cold. But that sleazy plastic film they sell to cover windows is always warm to the touch. 4x4 of warm plastic, makes you wonder what good all that gas and reflective foil is really doing if the result is still cold to the touch.
Same problem with drywall, it is always cold to the touch. So another time I would consider OSB. One downside to me is the stuff usually offgasses a long time and smells bad. If I had any confidence it had good glue, I would be a lot happier. but it is a commodity product so you don't know what you are getting.
One advantage to OSB
Bruce, a MN Galoot
Is that you can hang certain kinds of stuff anywhere -- you don't need to find a stud. Not heavy stuff, mind you, but light brackets, etc. My next shop will have walls of OSB painted white.
1/2" drywall over 1/4" plywood
RobCarr
This is what I have in my shop - the plywood keeps the drywall from getting damaged and also allows you to hang anything anywhere without worrying about hitting a stud.
Most of my shop walls are cinder block - so they don't count. The east wall is 1/2" plywood. I chose plywood over OSB because I didn't want to look at the painted OSB. I can hang anything anywhere.
It is slightly more expensive than OSB - more so if you think of all the walls you have to cover. I will say that the plywood was a LOT easier to paint.
Re: 1/2" drywall over 1/4" plywood
Jason Waters
If I were building a shop with wood frame walls, I would put drywall (for fire reasons) over 1/2" ply with insulation behind it.
No matter what, even if you don't add heat/air, insulate any wall you cover up, it just makes sense. Run any electrical you may want too.
For the garage portion, you could start by doing the back wall (usually where the workbench is and need for outlets, etc.), and then doing a another wall every 6 months or so as time and money allowed.
Options, Options, Options
I debated for a while - then chose drywall. I built my shop (30' X 30' with 10' ceiling) about 7 years ago with 2X6 walls on 16" center. I used french cleats to hang all my cabinets. Some of these have a few hundred pounds of tools / supplies inside and absolutely no problems. I did over insulate - and covered the studs with plastic prior to installing the drywall. I grant you it is easy to mar - but also the easiest to repair! I don't think the drywall is any more "noisy" than OSB, and it is much more fireproof (and IMHO looks a whole lot better). If I wanted to hang pegboard it would be no problem with french cleats & spacers. When I built the shop I had custom trusses built which allowed me to have an upstairs room. I installed a furnace and central air upstairs and store most of my wood there. So far my heating and air conditioning bills have been very low (in north central Indiana) so I am quite happy with my decision.
Bill White
My walls (all of 'em) are woodgrained look pegboard. Fully insulated. I've got a lot of accessories and some tools hanging within reach of specific power tools.
Ceiling is 1/2" sheetrock painted white.
12" X 12" cvt tile on the floor.
Bill
Paul Blackwell
I just finished my basement shop,, and used an OSB panel called Smartside panels. It has a woodgrain finish and is v grooved. Look at Shop Shot # 953 to see it. It's better than drywall in my opinion since you can hang things from it without necessarily hitting a stud. As I remember, it was about $25 at Home Depot for a 4x8 sheet.
Jason Roehl in Lafayette, IN
"Touch" is not a good indicator.
My brother works with some interesting chemicals and materials, all related to silicone and silicone products. One of those materials is a ceramic that is similar to the ceramic tiles found on the Space Shuttles. This ceramic can be placed in an industrial oven, heated through and through to 1500ºF, then removed from the oven with bare hands! The reason is that the ceramic has such a high insulation value that it simply does not transfer its heat to your skin fast enough for it to burn--the body can dissipate the heat at the very slow rate it is being transferred to the skin, even though a thermometer would still register the very high temperature.
Jason
Ron Jones
Even in an unattached building I was required, by local code, to use drywall. I could have put OSB over it, but the drywall had to be in place. Actually I like the look of the drywall better, and, like Larry, I use French cleats for hanging everything on the walls. You might want to check local zoning and insurance regulations before making your final decision.
Thanks for the input.
Joe Pack
Thanks for the input. I appreciate it.
