OT: tile over laminate countertop *LINK*
Stuart Johnson
Has anyone tried this approach to tiling over a laminate countertop? If it works it looks like a good option to building new tops.
Tavy Thin-Skin
Stuart Johnson
Tavy Thin-Skin
Re: OT: tile over laminate countertop
Bob Lang
Haven't tried it but it would make me nervous. What happens when the substrate/laminate bond fails? Old laminate isn't that hard to remove, get some solvent in under the laminate and it peels off the particle board, plywood or whatever is down there. The original substrate would be a better surface to tile to.
Bob Lang
Kneale Brownson
I'd try that if I had a laminate with a squared backsplash. Tough if you have one of the post-formed with rolled backsplash.
I think I'd also use a plastic putty knife rather than a steel one for laying down the paper.
Be careful about having the bullnose close to a stove. Too much heat can crack the tile. DAMHIK
Andy Lincoln,in Dearborn MI
Stuart,
I would suggest nailing/screwing hardi-backer to your existing CT first.
Hardie sells a tile backer that is 1/4" ~5/16" thick that would become a great substrate for tile.
33 Years Ago
I put ceramic tile right over Formica. Belt sanded the surface with 50 grit. Used vinyl floor adhesive; allowed 4 days to set, then grouted. Counters are still there as is the original tile and bullnose (with a few nicks , of course).
TomD
Another issue is how stiff your formica is. Probably fine but if it is not all that well supported, you need to start from scratch. I would use epoxy.
