REAL MILK PAINT
Another OT - Headliner "glue"??
My wife's car has a headliner that has come loose and is sagging in the back. The car is only 8 or so, so I don't really know why. But the fabric hanging loose is distracting (and not pretty).
Any good way to glue it back up? Which adhesive?
Re: Another OT - Headliner "glue"??
Elmer's white worked for us.
I have had success with 3m 77 spray adhesive. If you leave the windows rolled up you should be able to get a nice buzz too. Elmer's would be less odoriferous.
I have lots of experience
Bill Tindall
1. Get new headliner available from most fabric stores. The liner came down because the foam is disintegrated. Can't be reused.
2. Go to auto supply store that caters to professional body shops. Buy what they recommend to glue it back on. This is not a place to be cheap about the adhesive. The best work reliably.
You will need to take the old liner out. Typically it will be stuck to some cardboard. Rub off the old liner foam from cardboard. Apply plenty of adhesive and put the new liner back on.
George Colonel's Workshop-Havertown PA
Good Afternoon JL,
That happened to me in an older car, and I tried spray adhesive. The adhesive worked very well, but I couldn't align the fabric properly. It had stretched, and frankly, looked awful and ill-fitting. I wound up stapling it to the foam backer and that worked well, save for the staples showing.
It was a nice car, but I didn't have the money at the time to have it done professionally.
George
Re: I have lots of experience
Joseph Mulherin, Sr.
My Ford Aerostar headliner started to look messy too , so I took the cardboard headliner out of the Van, took it out to my table on my patio, stripped off the remaining liner, Went to Wal Mart and found some material which closely matched the interior of the Van and the previous headliner material. Laid out the material on the cardboard liner allowing about three inches overlap, glued up the cardboard and the liner material with the 3M 77 spray and smoothed out the material onto the cardboard and making sure that there were no wrinkles. Took the finished liner out to the Van, reinstalled it, and it looks just like it was factory made.
Also, went to Macco to see about having a repaint job done on the Van, they said $450 and they would not fix and scratches or dents. So, I said no, went home and got out my ROS and attacked the scratches and dents down to the bare metal. Sprayed with a rust inhibitor. Installed newspaper shielding all around the lower half of the Van under the windows, bought 3 cans of matching spray can paint from Auto Zone and proceeded to spray the Van with them...had only one run but not that noticeable. Waited a few days and then applied some wax and buffed it out. Came out really nice, and it only cost me about less than $50.
100+ years of building cars and this is their best
robb carr
I don't understand why after so many years were dealing with these problems.
Every car that I've owned that was a 1980 or newer has had this problem - its interesting to note that it only shows up once the car is well out of warranty. Its also interesting to note that this problem never occurred before 1978!
Re: 100+ years of building cars and this is their
Were you thinking headliners didn't collapse, sag, and fail before 1978? I don't know when you were born, but I sure saw headliners that resembled middle-aged men like me on older cars, going way back.
Keith Newton
George, A trick that I use, when gluing fabric or leather, which can be pretty stretchy, is to lay the fabric face down on a good smooth surface.
I then spray the substrate, and lay it down on the fabric as quickly as I can. No glue on fabric or leather, as it can bleed through on some. Then flip it quickly after, and smooth out from the middle, while pressing the fabric into the glue.
Stuart Hough
JL, I'll second the motion on 3M #77. That is what the pro shops use to redo headliners. If you do it yourself, don't scrimp on the fabric, get the best. One thing to remember...when you smooth the fabric out, DON'T use a lot of pressure. You will start breaking the foam and get the problem all over again in a few months. That was the mistake my brother and I made on my'85 LTD wagon.
Pete in Holland
Ditto on the pressure thing. Use a stiff long bristle brush, like a wall paper brush. Wiping it down with your hand is a sure way to get bleed thru.
The 3M adhesives spoken earlier work well. Cars can see 180F inside. Not all shop glues stand up to that kind of temperatures.
I have used Tite Bond in the past, and it worked well. Apply it to the substrate, then wipe the fabric into it with the brush.
