TV
TV
TV
Rancy Ceccotti
I have an LG flat screen tv model 42LV4400-UA that will not turn on. Are there fuses I can check and where are they located?
Re: TV
Re: TV
Dave Paine
Unlikely a conventional fuse.
Many modern electronic devices run on DC, I think LED and LCD TV's run on DC, which means there is a power supply/transformer.
This feels like the power supply/transformer has gone. Not a fix you can do at home. You may need to take to an electronics repair place. Be prepared for sticker shock. Likely $70 or more just to diagnose.
Consider the age. You do not say. If more than 3 years old, it may not be worth repairing. Sad to say, but this is the norm with modern electronics.
A new TV will likely be bigger screen, lower power consumption and far less money than the original.
Re: TV
Re: TV
Barry L Elder
Is it plugged in? :D :D :D
Re: TV
Jason Roehl in Lafayette, IN
I managed.
I have a Samsung LCD ('06 vintage) that wouldn't come on after a week of taking a few minutes to start every time. I opened it up and immediately saw 4 blown capacitors (fairly large ones). Realizing they were part of a separate power supply board, I managed to find the board online for $90 and replaced the whole board. Six months later or so, the TV popped and turned off while I was watching. Instead of replacing the board again, I just found similar spec capacitors from Radio Shack and soldered them into the old board. Swapped the old board back in, and it's been working for several years now.
You might try searching the exact model number online. You'd be surprised at what you'll find. Often the repair help will cover a fairly broad range of models as the physical layouts are similar and the only real differences are in the firmware (the pre-loaded menu and signal processing software).
Jason
Re: TV
Re: TV
Bill Howatt
Have you tried the front panel on/off as well as the remote?
Have you unplugged it for at least 30 seconds to reset everything?
Bill
Re: TV
Re: TV
Rancy Ceccotti
I do not have a remote but I have tried the panel on/off. I got this from a medical office who found it better to replace than repair. Rather than dumpster it I am trying to investigate. Thanks for your responses. Rancy
Re: TV
Re: TV
del schisler
go here with model number ect and find the part. This is the best and cheepest place to get parts. I would belive it to be the power supply board. I have been in repair for 50 yrs but retired now. It will ge a gamble ?? but if not that much it may work out for you. the address is http://www.shopjimmy.com/
Re: TV
Re: TV
Stuart Johnson
Barry asked if it was plugged in. He was joking but the cord on some TV's plug in the back of the set similar to a cord on a PC. It's along shot but possibly yours does and it's loose.
You do realize if everyone fixes stuff instead of throwing it away the nation's economy is going to get worse. Sales will go down, landfill employees and trash truck drivers will be laid off.
Re: TV
Re: TV
Al Goldstein
Digital electronics sometimes need to be refreshed. This means disconnecting them from the power source, waiting 30 seconds to a minute and then plugging them back in. Turning the TV off on the panel is not the same as disconnecting them from the power source. Try unplugging it and see what happens.
Re: TV
Re: TV
Rancy Ceccotti
Thanks Del
The link you posted has both a Main board and a power supply board. You think it could be the power supply board?
Good news/bad news Repair shops want $70-80 just to analyze. The power supply board sells for $79. If that is not the problem I can always resell it through e-bay.
Thank you
Re: TV
Re: TV
del schisler
that would be my guess. Does it have a remote i guess it does. Now that little sensior could be bad and not turning it on also with remote ? But now if you have a button that you push to turn on tv. that bypass the senser that is activated by the remote. If it doesn't turn on i would go with the power supply. I guess it is a crap shoot not truble shooting . let me know how it turn's out. del
Re: TV
Re: TV
Rancy Ceccotti
Del: I do not have a remote but when I use the on/off button on the set it still does not respond. Is there a test to determine if the problem is the main control board or the power supply board? I looked at ShopJimmy. A new power supply board is $80. But he is out of stock. At partstore.com a rebuilt power supply board is $63.
Rancy
Re: TV
Re: TV
del schisler
not unless you have a good volt meter and a schamatic of the board. Now most will just replace the power supply. A rebuilt one if fine if it will have a warrenty ?? Is that exchange module. sometime they don't want the old one . Their is a circuit or two on that board. Their is probly a scr that turn's on the power supply someting like the off and on lamp's that are touch type. It is more that one componit . I would give that a try not to much money. Now do you have a meter of some kind to make sure that the line cord is 110 volt ?? You could take the back off but be carful about letting the back drop! Hard to tell if their may be someting on it. At where the cord come's in that is where the power supply is now carfully check for voltage their just to make sure that one side of the cord in the plug didn't come loose. Cheep made. other than that a board . good luck let me know how you make out. del
Re: TV
Re: TV
Rancy Ceccotti
Del: Thanks for your reply. Since I wrote you the note I called Nohoelectronics and spoke to a tech. He walked me thru a series of things and said that particular model has had a flaw in the main board that they have seen numerous times. You send them the original board as long as it has not been altered, they test it, repair it and return it. $109 and 1 week. Before I send it off I have already requested information on warranties. I will keep you informed and thanks for your help.
Rancy
