Have a question? Ask Woody!
Plate joiner question,
Keith Newton
I'm needing a new biscuit joiner, and liking the looks of the PC 557. I was wondering if any of you have this one, and how you like it.
Are there any negatives? My current one is a PC, which a friend gave me when my old Virutec died a few years back. I can't believe how poorly designed the fence and base are on this piece of junk. Is this one designed to operate smoothly, and substantial enough to hold up over time?
Re: Plate joiner question,
Yes
Yes, the 557 is an excellent plate joiner. It has one quirk, which isn't a deal breaker, and that is that because of some arcane litigation years ago, they were forced to set the bearing surface back 1/16" from the face of the flip fence, which can pose an inconvenience if/when you need to get the fence out of the way. (Sorry for the foggy description.) You can permanently and completely fix the issue by gluing a thicker rubber pad on that front bearing surface.
I particularly like the way the fence flips over 135º for miter joining. And you're right, their old joiner, with the vertical handle, was pretty bad.
Re: Yes
I have that model and I like it. (I don't use it as much as I thought I would, but that is not the fault of the machine. I just don't find as much use for biscuits as I thought I would.) I was not aware of the fence issue until I read it here, and I still have not noticed it. I may look closely next time I get it out, if I remember. The fence is versatile and I would buy this machine again.
The only "issue" I have is the machine is long and the trigger is on the handle, a long ways form the business end. Makes it sort of nose heavy. Just seems there could have been a better balanced design.
Thanks Ellis and Barry
Keith Newton
I think the switch is better located on this one, than on the one I have, so I'm not bother by that.
I like the idea that it has as much amp / power as it has. I was a bit unsure about the open frame or ring which indexes on the face of the board, but the more I think of it, the better I like it.
I do plenty of weird projects, so it may come in handy for some of them. Otherwise, I think I am really going to like the dust bag. When it gets hot, I work in front of a big fan, which can send the chips up into my eyes, when I use the old one.
Re: Thanks Ellis and Barry
NickinMass
That dust port is a two edged sword. With the port open, I would get at least one wood chip flying up under my safety glasses and into my eye every time. Until I got smart enough to ALWAYS use the shop vac with my plate joiner, I would have to look away or close my eyes when I pulled the trigger (this may have have had a negative effect on accuracy ;-)).
Re: Yes
Jason Waters
Ellis,
My 557 doesn't suffer that ill effect. I bought mine prior to them having to set the fence back. I don't see why they don't change it back, after all, it was Dewalt that went after Porter-Cable, and subsequently bought them! Does anyone know if they changed it back?
I love my 557. It can be tricky when trying to biscuit near the end of a board, but that's most plate joiners I presume (I've only ever used the DeWalt and Mini-Ryobi otherwise).
I've used the face frame biscuits a few times and they are handy, though it takes a few minutes to switch over to the face frame blade.
Use the Dust collection (I have a hose, I have several PC tools that use it) and it works better I think because it keeps junk cleared.
That being said, there were a lot of biscuit joiners bought that have very little use (Even mine has very little, only make stuff for my house, and a few other things) out there on the used market. I'd look for a DeWalt, or preferably, the PC 557.
Jason
Re: Yes
Yes, Jason, it was the Type II model that has the setback, and you raise a great question. I will actually be at a press conference on Wednesday in New York with all the top product guys at Stanley-Bostitch, so I'll try to remember to ask that question.
Re: Yes
Jason Waters
Ellis,
That would be a great question.
I know mine was probably from the first few months of production, it had just come out when I bought it. I was actually saving for a DeWalt, when the PC came out, and got it for a few dollars more (maybe $20-30) at the time. I have a funny brand-like based on the type of tool, and like a lot of PC tools, or at least the old U.S.A. made ones. I don't have too much new stuff these days, most I bought quality, and haven't come close to wearing them out.
