Happiness is a pile of new blades
John in NM
Blade welder working fine now, all except the annealing function. Doing that with a torch for now. I bought the spools ages ago, so each blade cost about $4.25
It would be closer to $7.50 these days.
John in NM
Nifty!
Bruce, a MN Galoot
What kind of coil stock is that?
4 tooth hook
John in NM
Morse brand. I get it from Victor Machinery in Brooklyn, about the cheapest place I've found.
tell us more....
Bill Tindall
about the blade welder. Something one can cost effectively buy?
Re: 4 tooth hook
Bruce, a MN Galoot
How does it cut and hold up? Decent for all-purpose work, occasional resaw?
How's night shift? Mine sucks.
Re: Happiness is a pile of new blades
I really can't tell from the picture if they are properly sharp and set. Send them to me, I'll test them for a while and then I'll send them back with a full report.
T.
Re: 4 tooth hook
John in NM
Last batch I had was 3 tooth from the same vendor. I'd silver soldered those blades. Held up well, about like any other carbon steel blade. Teeth are set more for general purpose use than resawing. Works fine but cut is a bit rough compared to a real resaw blade.
I haven't done much cutting with these yet, just got home from the telescope. I'm hoping these won't have the tendency to break at the joint that my soldered ones did (my fault, not the solder
Night shift is over for the month, thankfully. Another one in June, then its all days until October or so when the moisture goes away and we start observing again. Hope yours goes quickly
Re: tell us more....
John in NM
Mine was a gift from a friend, an old Do-All welder that came from the shop he worked for (repairing and re-selling machine tools). It sat around for a year or so as I tried to order parts, but in the end I gave up and made the missing bits in the machine shop at work. Then it sat for another year or so until I got around to figuring out why it wasn't welding (congealed crud in some moving parts). Probably be another year before I take a look at the anneal setting.
Unfortunately, I believe these things aren't cost effective for most woodworkers, unless you buy a lot of bandsaw blades in a year. Last time I checked, a new welder was several hundred dollars (from Grainger), but saving $10 or so per blade might make it worth it for some. If you luck into a used one like I did, they're a nice thing to have. You see little units like mine on metal cutting saws all the time, my friend tells me its quite common to cut and reweld the blade to do inside cuts in metal - the kind of thing we'd do with a jig saw.
Joseph Mulherin, Sr.
Bill, go on YouTube and type in "bandsaw repair" and up will come some videos showing a guy who made his own rig...very cheaply. You can buy the silversolder at Lowes and HD for about $15. Charles Neil also has a video showing a rig from Woodcraft he uses....about $42.00 tho.
Pretty cool but I can buy custom made blades from a local blade sharpener for $6 for 105" blade. Probably wouldn't be worth it for me to buy a welder.
Two kinds of silver solder...
John in NM
Soft - mostly tin, available at HD, Lowes, hardware store, etc.
Hard - an alloy of nickel and copper that is quite strong and melts at a much higher temp than soft solder. Available from jeweler's suppliers, and machine tool suppliers.
A hard soldered bandsaw blade should be every bit strong enough to tension and use until the teeth wear out. In practice, the dry fit of the splice has to be perfect to minimize the thickness of the solder. I made 20 or so this way over the years and all but two or three failed at the splice before the blade became so dull I wouldn't use it. The one I just replaced was a soldered blade that had run for a year or more and was so dull I could hardly stand to use it. Got that joint right anyway
Of course I've never tried using soft solder on a blade, it might work fine if you have a good fit.
soft solder will NOT work
Dick Coers
You need the expensive hard solder, very close to brazing. It is important to make a skive joint. I bevel the edges on my disc sander so I get a much longer silver solder joint. Works great. I silver solder blades from 1/4" to 3/4" and even touch up the teeth when it gets dull. Never had a joint snap since I keep it clean anduse a really good flux. Get your supplies at a welding supplier.
Yep, that's about what I used to do...
John in NM
Except I just butt joined the ends, part of the reason they would fail I suspect. I had just read about the proper joint when I was given the welder. Never thought to ask about hard solder at the welding shop, that makes a lot of sense, and any reasonable size city is going to have a supplier.
The jig is easy to make for anyone who wants to try it. Just an aluminum angle (for clamping in the vise) with an aluminum bar screwed or riveted on the top to make a straight edge. After that's installed you just cut a kinda U shape out of the center (doing the cut last ensures the two straight edges are co-linear). Then use two heavy binder clips to hold the blade ends to the jig. I used a propane torch for the soldering a few times, but really had better luck with an air-acetylene torch like a prestolite or turbotorch. One of those little oxy-propane deals would work too if you can stand to buy the oxygen cylinders.
