all watering is not created equal
Bill Tindall
I irrigate and that focuses one's attention on applying water to stuff, effectively. Some things I have learned:
In you case, water at evening or night if practical. You won't have fungus issues with grass.
It is likely that you will vastly underestimate how much water you are applying. Put out a measuring device. I watch people "water" with a hose and spray nozzle and know from my measurements they aren't effectively watering at all. The Ag office says I loose 2 inches of water a week when it is 90. A good bit of this water comes not from rain but from water stored in ground during winter. However in the sod case there is a discontinuity between the new sod and the base dirt that will hinder water transport up from the ground for a while. So I would guess that you will need to water sod more than pasture until the roots find their way into original dirt.
Grass, at least my pasture grass, can recover from dryness stress. So, I would presume that if the grass gets wilty it can be rescued with water. But, I think the objective is to get roots from new sod into original dirt and that process will be accomplished fastest by never letting the sod roots get stressed.
