Electric Heater for Workshop
Joe Pack
I live in southern Indiana. I have a soon-to-be-completed 16x28 workshop that I need to plan heat for. That gives me about 450 sq. ft, with 10' ceilings. The walls will be insulated to R-13 and the ceiling to R-38. Electricity is the only practical option, but I'm not sure of what hardware I want to use. I have considered strip baseboard heaters, but have also read up on highly recommended (by customers) single units, either portable or wired-in wall/ceiling mounts.
Any ideas on which would work out best?
Re: Electric Heater for Workshop
I vote against baseboard units for two reasons. Dust settles. Wall space is valuable real estate.
Woodstove or Pellet Stove
Dustmaker Mike
are you going to keep it heated full time? If so you might want to use a wood stove or pellet stove to offset the cost of the electricity. I went with a gas heater mounted to the ceiling for my heat. I think the radiant heaters hung from the ceiling would be a good bet on a thermostat would even be better.
Enjoy
second this unit
DizD
I have similar sized shop (500 sq ft) with this unit. Best thing I've done. I keep it on low(50 deg) all winter - it will heat shop to mid 60's in 15 minutes or so. But the absolute best thing was, I found it on closeout shelf at Northern during the spring - marked down to $75. I think you have to balance cost of elec with convenience. If your shop time is irregular like mine, being able to go work for an hour or so when you want without having to do anything but turn the dial for heat is worthwhile.
Re: Electric Heater for Workshop *LINK*
Paul Cates - Henderson, KY
My previous workshop was an attached 2 car garage. 9' ceilings, 2 windows, and an uninsulated overhead aluminum door on 1 end which faced west (think wind blowing through the sides of the door). A 5600 watt portable contractor heater worked well for me, although on colder days I'd have to start it a few hours before I went into the shop. I purchased the heater at the link below. It's not the best organized site, but they have very good prices and selection.
Electric heaters
Jim Dillon
Joe,
I installed two original Markel "Bulldog" electric heaters in my roughly 1100 sq.ft./10,000 cu. ft. garage seventeen years ago. The garage is well insulated. I picked the heater size based on keeping the garage at 55 degrees if it was 0 F degrees outside. They work very well and I probably could have gone with a lower BTU output as it doesn't get to 0 degrees much anymore. My heaters look a lot like the one posted by AZ in Colorado Springs except no louvers. The built-in thermostat is a nice option. The newer "Bulldog" heater is round (see link below) and I don't like the style of it much, but I guess it does the same thing. Here is a link to Markel's web site.
Jim
Markel Garage/Shop Heaters
Bill White
Don't have to deal with extreme temps very often here in Mississippi, so I use oil filled radiators in the shop. Most days a single radiator will do just fine.
My shop is fully insulated,thermal windows and doors.
Bill
Christopher Fitch Memphis
I have a heater similar to this:
http://www.amazon.com/Delonghi-TRD0715T-Safe-Oil-Filled-Radiator/dp/B000A33B1C
Takes a bit to warm up but once it does, it produces a decent amount of heat. I can keep my 13'x19' shop up to 80+ in the winter easily. It rolls out of the way and is stored easily in the summer.
Dave Bair, Eaton Rapids, MI
I use the quartz radiant ceiling heater from Lee Valley. It runs on 120 v and has two settings. It keeps my 20x20 shop in S. MI 40º above the outdoor temperature. I leave it on the low setting overnight to keep everything above freezing and set it on high about an hour before I plan to work. It costs less than a dollar a day for electric.
Thanks to all
Joe Pack
Thanks for your input folks. I appreciate it.
