ADVERTISE HERE - FREE TRIAL
Curved Table Skirt Tenons?
Tony - Memphis
I'm building a small round topped table wiht curved skirts. I brick laid the skirts and they are about ready for veneer. I have several ideas on cutting the tenons on the ends, btu I thoguht I'd ask if anybody had any better ideas! Looks like it will be tough. Any ideas?
Thanks,
Tony
Re: Curved Table Skirt Tenons?
Jesse Cloud
Yup, lots of ways to skin this cat. Most of the folk I know who do this make a 90 degree jig, with the vertical part for clamping and the horizontal part for the tool that cuts the mortise. The curved apron has the appropriate angle already cut, so all you need is a way to clamp that angle securly against the horizontal part of the jig.
You can do a version of the jig that will cut an integral tenon, but that takes a lot more 'splaining'. Let me know if thats really important to you. I always just use floating tenons for this.
Sled for TS, template or fixture to hold parts,
Keith Newton
The template fixture, may actually be a quarter circle, which holds the part up in end, against the fence. The blade height, is the tenon length.
If your sled is old, and has been used with dado blades, I would brad or screw on a fresh piece of MDF, so the blade has a zero clearance kerf. This makes it easier to hit the marks perfectly, and if not, to go back for just a few thousandths more.
Nick Tuzzolino
When I built a similar table I used "slip tenons" or 'floating tenons"
Splines should also work. Cut the slots using the joint and outside surfaces as registrations. Remember to orient the spline grain across the joint. Less fussy than trying to line up holes for loose tenons or dowels.
Concur
George Colonel's Workshop-Havertown PA
Good Afternoon Tony,
Of the options you have, I believe Mark's suggestion is the one I'd follow. Less fuss.
George
