Pocket Mortise Mill
Woodie49
Has anyone used one of these? http://www.jessemdirect.com/Pocket_Mortise_Mill_p/08200.htm?et_mid=557831&rid=3255096
What do you think?
Thanks
Pocket Mortise Mill
Woodie49
What do you think?
Thanks
Re: Pocket Mortise Mill
Kneale Brownson
No experience, but wouldn't a biscuit joiner do the same thing? And be faster? and the biscuits would be a third the cost.
loose tenon
McKay
The loose tenon or mortise and tenon is a MUCH better joint than a biscuit joint or a screw pocket joint. Really there is no comparison. The domino from festool is a good example of a quality loose tenon. I used one quite a bit when I still taught. Because of the cost, I personally use the Beadloc system when I want a loose tenon. Very effective and inexpensive. I have a number of Jessum tools and they are very well made and worth the money.
Re: loose tenon
Kneale Brownson
Is it stronger because it's "real" wood, while the biscuit is compressed wood bits?
Jesse Cloud
There's a thread on one of the Festool forums. Couple of people have seen it, general consensus is that it is pretty cool if you only have to do a few mortises.
All agreed that the price is awesome, especially for something actually made in Canada!
Re: loose tenon
Cross sectional area. As an example, I might have a loose tenon that is 1/4" - 3/8" thick, 2" wide and 2" long. That's a lot larger piece of wood. The edges are also "square" as opposed to being a "football" like a biscuit.
I have a biscuit joiner and use that when needed. I use it to put on face frames, align pieces of wood, etc. All my aprons are usually joined to my legs with loose tenons or regular tenons.
I'd have to try it
A cordless drill running at 1200 rpm or less seems like it's really underpowered for serious mortising.
Can you try it before you buy? I'll be seeing these guys at IWF in August, but I can't give you an informed opinion right now.
Re: I'd have to try it
Woodie49
You drill a series of 1/4" holes befor cleaning up. You can watch a video here; http://www.jessem.com/POCKET_MORTISE_MILL_II.html
