We value your privacy.
You do not state if you have rust, or just the grime which can build up over time.
If you have rust, then a product like Boeshield or Autosol can remove the rust. Both are available at Lee Valley.
If you have grime, then using 600 grit wet/dry abrashive with some oil for the "wet" will do wonders. The oil will act as the fluid and will mean no residual moisture. I happened to have used this technique only a few days ago on two rust spots on my disc sander. The spots felt "rough" but after a few seconds with 600 grit and oil they were smooth with no rust.
Given the problems that even 1 molecule of silicon seems to have on finishing I would not use any wax that contains silicone. I make my own. Carnuba plus xylene.
Steel wool and wax makes a decent cleaning procedure.
I do pretty much the same as what Bill does. It doesn't matter to me if my tops are shiny, what is important is that they slide smoothly and wax does this really well and is cheap. I won't sand my tops I see no reason to go that far and stains don't bother me at all. So the most aggressive I get is 0000 steel wool.
I'm with Thomas in this matter. I don't care about the few stains my top has; they're character in my eyes and shows frequent use, which is what a working saw should reveal.
I'm more interested in how well the stock moves over its surface. To that end, I simply apply a coat of Johnson's Wax when necessary.
If I'm cleaning or removing a bit of surface rust I go with WD-40 and a gray Scotch-Brite pad and then apply the wax. The WD-40 rids the surface of moisture while the solvent and the pad loosen and remove grim and light rust. I never shoot for a like-new look because it won't stay that way around here!
Take a piece of heavy duty aluminum foil (wear gloves) and fold it so the "dull side" is out. Put a couple of drops of water on the table top. Scrub with the foil. Repeat as needed.
The aluminum oxide on the exterior of the foil acts as a light abrasive. The water acts as a lubricant. You also set up enough of a chemical reaction between the rust and the aluminum oxide to help things along a little bit.
For heavier stuff, I use sandpaper - either silicon carbide wet/dry or heavier duty aluminum oxide. I sometimes use abrasive pads and WD-40 or mineral spirits.
Scrapeing scares me on anything. Just mineral spirits. A bit of steel wool if its REALLY on there. Scrub, scrub, scrub, then a machined surface's best-est friend : good ol' Johnson's Paste Wax.
sears store's has this product now. With these you will not have to scrub very little I wouldn't use any oil on my saw unless you get it all off. Finish's don't like oil or wax. The wd-40 may be ok but i don't use this stuff. The WD stand's for water displacement that was what it was made for? If their is some rust the rust off will get it to looking like new. and the T-9 will keep it looking that way. These product's were mfd. by boeing aircraft co. Works for me i haven't had any rust on any of my tool's i live in eastern florida 10 miles from the ocean. my 2 cents
I hate rust or blems on my table and band saw surfaces and use a ROM w/grits as heavy as 120. Mostly 220/320 is responsive. Then paste wax. Mine are tools used daily, not museum pieces, so I don't fuss.
