Question about Chestnut
Dan Jechura
Does anyone know if Chestnut is a good wood to use out doors. It will be on a outside door with no storm door. Also what would be a good finish for this wood.
Thank you for your time.
Dan J.
Dan Jechura
Dan J.
Re: Question about Chestnut
It will do nicely outside if coated. Coating of choice in this application is minimum 2, better 3, coats of a good spar varnish.
TomD
It holds up as well as most. I have some pieces unfinished on my deck as a sort of railing. It weathers, but has not fallen apart in 15 years. Better than oak. I seem to recall reading that enormous amounts were used in barn boards or rail ties, in Penn.
David Yoho
I think it is as good as anything else you could use outdoors. I've seen it where it was so hard you had to pre-drill it before nailing. The best finish would be paint but, short of that, I'd go with a spar urethane varnish.
Bill Tindall
It made good fence posts in its day and was used extensively for barn/house siding. But.....Given the rareness of this essentially extinct species I only use it in applications were I expect it to last centuries, not decades.
Finish use Sikkens Cetol *LINK*
Dave Paine
I have a sidelight on the left of the front door which I made from a mahogany species (I do not know the exact species). This does not have any storm door.
I finished with with Sikkens, made by Ciba Geigy. A two part process. Apply the first part, wait a year then apply the second part.
This had held up better than any spar varnish I have used. This is not cheap, but this product will hold up longer than a spar varnish.
The final coat is good for a few years. I just applied a second coat before this last winter. A light hand sanding to rough the surface and then apply with a brush.
The link is for the products sold by the Borg. Paint shops will carry more options.
http://www.sikkens.us/en/Products/HomeDepot/Pages/default.aspx
Dan Jechura
thank you all for your help.
Dan j.
