Re: Thanks, colleagues, but things seem broken
Carol
The test cable is a good idea.
However, in my past i worked as a tel-technician in CA for 15 years, and with that in mind, I remember some of the things I ran into trying to fix this sort of thing. Something caused the copper to fail and it might save you a bundle to find out what. Mice and corrosion are most likely here. Whichever, these are two problems that will have other consequences. Mice and other critters can cause a lot of damage. Moisture getting in places it ought not to be is even worse.
Here is a tip. Trace your wire from box to box. Get a picture of how the wire runs. Keep that picture in your head or draw a simple diagram. You will only have an idea from the boxes you can find without digging into insulation and such. The runs are not always intuitive! Open the connections and temporarily connect your test wire as a long jumper wire from one available box to the next and see what happens. Keep doing that until you have found the problematic section. When you remake the connections, make sure they are secure and moisture proof.
If you know how to use a VOM, it is even easier and faster. Look for resistance (a short) between the wires, and then a short to ground between them individually. Then twist a pair together on one end and test for a short between them at the other. Repeat for other pairs.
They have intended pairs. Sometimes over the years and attempted repairs, unmatched pairs are made, but not everywhere. That can really screw up the soup. If you need to know the intended pair colors, they are easy to find or post here and we'll help. There have been many color combinations over the years, so we will know what you have now. Which brings up newer colors connected to older colors. Also a source of a possible problem.
Let us know. We are here to help.
