Soapstone Workbench Top
Jp
I have access to a soapstone slab that I was considering using as a bench top. Certainly ought to be heavy enough...but does any one have any experience with working with it? Is it brittle? What would I have to worry about when attaching a vise to it? Bench Dogs?
Any thoughts?
Thanks,John
Re: Soapstone Workbench Top
Bill Tindall
This material was commonly used for lab benches so it certainly will hold up to modest forces. And it was drilled and sink fixtures fastened to it so it is strong enough for modest bolt holding. But if it, like all rock will have poor tensile strength.
mdclor
It might be a little rough on any sharp edges that may happen to come into contact with it. Of course, none of MY chisel blades, drill bits or saw teeth have ever touched my bench top. LOL :D
Likely not
Bill Tindall
This stuff is very soft and I am sure it could be carved with woodworking tools.
Re: Likely not
Jp
I think it can also be turned. As Bill mentioned in his original reply, it is an old lab table and it does have some sort of a coating that covers the soapstone. My concern is attaching a vise to it so that it'll stay there and be able to do what vises do. FWIW, I have 2 slabs of it and have thought about laminating them together hoping that that would help solve the potential lack of tensile strength problem.
Dick Coers
I've only worked with chunks of soapstone, not slabs, but everything I have worked has had some veining in it. It is a sedimentary stone, so different settling of minerals make these veins. I've had a whole chunk fall off. With that in mind, I wouldn't want to strike anything on top the bench in fear of cracking.
Moses Yoder
Moses Yoder
It would make a wonderful top for a sharpening bench.
Mike Johnson - Chicago
I installed 32' linear ft of soapstone in my kitchen and (although worse than MDF dusty to work) love the material, but I would not use it for the top of a woodworking bench.
The hardness of soap stone can range substantially, but in the end it is not a surface you want sharpened steel edges touching, and it chips fairly easily.
That said, it is a wonderfully dense material and would might make a great base to mount a wood top onto. If flat, it will remain flat and the weight will allow you to have a thinner sacrificial top.
The other option would be to use it for a lathe bench :)
