We value your privacy.
What would be the best glue to use to adhere seashells to a wooden table? And is it OK to paint the table with latex paint first, and maybe rough it up a bit after painting; or should I glue the shells onto raw wood? The only reason for the paint would be if there is space between the shells, the paint would be about the same color as the shells.
That's an interesting question. For "shell craft" - we used hot glue and hot glue guns. I've also used construction adhesive. I suppose a clear epoxy would work. I don't know if I would go with a CA type glue.
Then don't expect the adhesion to be any better than the paint to the wood, or the top layer to the one under it, which won't be much.
How good does it need to be, and will it matter if the adhesion to the shell can't be cleaned off?
Something heavy viscosity like liquid nails would be a good choice, but something like clear silicone might be good enough, and look cleaner, but takes a bit longer to dry.
As mentioned, gluing to paint isn't usually a successful practice. But, you can color the wood without having a meaningful reduction in adhesion. To do that use a dye (not stain) to color the wood. Dye, unlike stain, doesn't seal the wood. Of course, dye doesn't have a binder to hold it firmly to the wood, but unless you expect much stress it will be OK. You could of course spray the whole project with a light clear coat after the shells have been glued. (Be aware the clear coat will most likely impact the dye color so check out the clear coat before you settle on the exact dye color.
