sawblades
sawblades
sawblades
BILL MCEWEN
I used my good cutoff saw blade to cut laminate flooring, and now it just burns anything I try to cut. Just wonder whether it's ruined, or can be resharpened, or just coated from the flooring material.
Re: sawblades
Re: sawblades
Alan in Little Washington (NC)
Most laminate flooring has a very hard multi-step finish that includes aluminum oxide in a least one coat. Its the same aluminum oxide used in sandpaper grit!!
Your blade will probably be ok once sharpened.
Re: sawblades
Jesper, Denmark
Re: sawblades
Jesper, Denmark
Easy to test - clean the gunk off with your favorite solvent or oven cleaner and make a testcut.
If still burning, it's off to be resharpened.
Re: sawblades
Re: sawblades
Jason Waters
This happened last year when I cut flooring for my son's room. It was dull as heck. However, I still think it was worth it. Most laminate floor guys I have seen come with a jigsaw and that's it....Now I know why.
I sent my DeWalt Series 60 or 80 12" (one of the old good ones Made in England) off to Forrest and had them sharpen it. It turned out to cut better than it did new. This was a triple chip blade. I also had them sharpen my ATB 12" and a 10" tablesaw. All really nice.
Have it sharpened.
Re: sawblades
Sharpen it
Hoa in Alameda
Laminate flooring is blade killer. I've been through several laminate flooring projects; each time I just bought a cheapo blade, and tossed it after the project. The price of the cheapo blade is less than sharpening cost.
A sharpening job should be all needed to restore your blade.
Re: sawblades
Re: Sharpen it
Jason Waters
Hoa,
I will probably do that as well next time. Great Point!
If one was doing a whole house, it might actually pay to buy a cheap 10" saw and use cheaper 10" blades than the 12" I use......
