What is "stringy lubricant"?
Bill Tindall
I am cleaning/ rebuilding an Aro ROS and it calls for lubricating the o rings and seals with "stringy" lubricant. Not familiar with this term.
Also the gears are to be lubed with "5 lb EP NLGI #1 grease. That one has me stumped too.
Re: What is "stringy lubricant"?
Gerry In North Surrey
Aha! At last something that I can reply to. I am active in the 7 1/2" gauge miniature railway hobby and they use what they term "sticky oil". We buy ours from Chevron, it's an oil that has an additive that makes it 'sticky'. If you put a drop of it on your finger and touch it with your thumb it will stick to both digits and form a 'string'. Theoretically it is not displaced by water in a joint and stays in place longer than a non-sticky oil. We use it to lubricate the valve gear and driving rods on miniature steam locomotives. Your local Chevron bulk dealer should be able to supply it or possibly a well stocked auto parts house could have it. The folk at Sacramento Live Steamers should have a small quantity available or know where you could find it.
Gerry, who's staying home today because it's pouring rain here and steam engines have lousy traction on wet rails.
craigd
craigd
Phil's Tenacious Oil is another stringy oil, you can get it at bicycle shops.
A long time ago, I was helping my uncle rebuild something on his International Scout and he used a very stringy grease, I have no idea what it was, I just remember the amazing strings.
sounds like chainsaw bar & chain oil
