We value your privacy.
i am wondering about building an aluminum foot/leg myself because I can't weld & can't afford to have it done. Imagine 90 de. angled peice made from 1/2" stock. cut 4" long
One piece, 1/2 x 6" bolted to the mounting plate, 1/2 x 1.5".
I was thinking drilling & tapping & assmble with a 1.25" long by .25 bolt.
Before you get too far into this, I would suggest, if you live in a city large enough to have a metal recycling business, contact them to see if you can browse through their aluminum piles. Here in LR, the aluminum building is about 20000 ft, with bins half the size of a boxcar, piled high with end cuts from commercial glass fabricators. There are tons of wonderful extrusions that can be used for other purposes like you need. And the great part, is that it can be bought at a tiny fraction of the new cost.
As for the suggestion of the brasing rod, while it sounds wonderful, I'm pretty sure you will need a oxyacetylene to get the temp of your parts hot enough. Aluminum is an extremely good conductor of heat as well as electricity, so on those thick parts, the mass will really pull the heat away from where you want it into the whole mass.
You might do fine bolting, but also don't forget about adhesives like JB weld, especially if it can gain structural integrity from the part it is going on.
Thanks for the ideas I might just check out our local metal recylcer.
Today i spoke with a metal shop & they are pricing it up for me.
It has to either be lacquered or anodized too. Anodizing sound fairly affordable but i have to see an example of the colour. I am also considering square tube & filling it with a piece of wood & screwing in some .25" x 4 x 4 base & bolting thatto the cabinet?
